Det er et puslespill og sette sammen dataene for dette prosjektet men det jeg har til nå er
Bass ht
CW1526C cast frame.
FS is 26.3, Re is 3.36, VAS is 506.3 Liters, BL is 12.49, QM is 9.93, QE is 0.27, QT is 0.26. Sensitivity is 97 db. Coil is 1 mH.
Pmax is 150 watts. Xmax is 7.15 mm, MMS is 75.5 grams, Cms is 0.486 mm/N
Mellom tone Selenium d405
SPECIFICATIONS
Nominal impedance. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 8
Minimum impedance @ 2,900 H z . . . . . . . . . . . . . . . . . . . . . 6.8
Power handling
Musical Program(w/ xover 500 Hz 12 dB/ oct) . . . . 150 W
Sensitivity
Frequency response @ -10 dB . . . . . . . . . . . . . . . 300 to 7,000 Hz
Musical Program(w/ xover 1,000 Hz 12 dB / oct) . . . 200 W
On horn,1W @ 1m, on axis . . . . . . . . . . . . . . . . . . . . 110 dB SPL
On plane-wave tube,1mW . . . . . . . . . . . . . . . . . . . . 116 dB SPL
Throat diameter . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 50 (2) mm (in)
Diaphragm material . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Phenolic
Voice coil diameter . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 100 (4) mm (in)
Re . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.0
Flux density . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.60 T
Minimum recommended crossover (12 dB / oct). . . . . . . . . 500 Hz
Magnet material . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Barium ferrite
Magnet weight . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2,640 (92) g (oz)
Magnet diameter x depth . . . . . . . . . . . . 200 x 24 (7.87 x 0.95) mm (in)
Magnetic assembly weight . . . . . . . . . . . . . . . . . 7,740 (17.06) g (lb)
Housing material . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Plastic
Housing finish. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Black
Magnetic assembly steel finish . . . . . . . . . . . . . . . . . . . . . . . . . . . . Zinc-plated
Voice coil material . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Copper
Voice coil former material . . . . . . . . . . . . . . . . . . . . . . . . . Polyimide (Kapton )
Voice coil winding length. . . . . . . . . . . . . . . . . . . . . . . 7.0 (23.0) m (ft)
Voice coil winding depth . . . . . . . . . . . . . . . . . . . . . . . 4.1 (0.16) mm (in)
Wire temperature coefficient of resistance ( ). . . . . 0.00329 1/°C
Volume displaced by driver. . . . . . . . . . . . . . . . . . . . 2.2 (0.078) l (ft )
Net weight . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 8,300 (18.30) g (lb)
Gross weight . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 8,520 (18.78) g (lb)
Mellomtone Horn
Heter M2380 og skal være en kopi av JBL2380 hornet ut over det har jeg ikke forsket så mye på saken
satser på at ferdig konseptet passer meg fint
Diskant
Crites CT-125 diskant bruker en Eminence driver som har en følsomhet på 104db/1w
mere info om den har jeg ikke funnet.
Delefilter
Deler ved 500/5000hz så mye mer enn det har jeg ikke funnet ut. Satset på en ferdig konstruksjon fra Bob Crites.
legger ved pdf fila til selenium driveren for de som er interessert
