Acoustic Solid
  • Vi har nå fått importen av Acoustic solid.
    Vi forhandler også Dr. Feickert, Project, Oracle Audio, Townshend, Wilson Benesch, Bergman, EAR og J.C Verdier
    AUDIO AKTØREN
    Storgata 22
    3181 Horten
    Tlf: 33074411
    mail: terje@audioakt.no
    Solid Royal
    The Acoustic Solid Royal is our state of the art model and represents the culmination of our development to date. A separately located motor isolates the platter from any motor induced vibration. The 70mm thick high-mass platter acts as a very effective flywheel to smooth out any residual cogging from the motor drive. The combination of an acrylic sheet and natural leather in the platter mat provides excellent damping of vibrations within the record. The platter rotates on a high-precision bearing of our own design and manufacture. This uses a plastic sleeve that is cast between the bearing housing and the spindle to provide what is essentially a "zero tolerance" fit. The bearing housing is mounted onto an 80mm thick aluminium chassis, which acts as a very efficient vibration sink. Provision for three tone arm bases is provided to allow the maximum flexibility in system configuration.
    The Acoustic Solid Royal provides analogue playback of great naturalness and musicality. Stereo images are focussed and stable; dynamics are impressively realistic and background noise is all but negligible. When used in a system of the appropriate quality, you really can feel that the musicians are in the room and playing for you.
    Platter:70 mm thick aluminium machined from a single billet
    Mat:Natural leather (royal blue) with a 5mm thick acrylic layer
    Feet:3 feet, each height adjustable and individually decoupled with special Teflon washers
    Motor type:Synchronous
    Control:Microprocessor controlled power supply
    Drive:String-drive by a separately housed motor
    Chassis:80 mm strong aluminum body, prepared to mount 3 tone arms
    Dimensions:440 x 440 mm; 240 mm
    Weight:Approx 50 kg
    Solid Edition
    Platter:50 mm thick aluminium machined from a single billet
    Mat:Natural leather with a 5mm thick acrylic layer
    Feet:3 feet, each individually height adjustable
    Chassis:40 mm strong aluminum body
    Dimensions:440 x 440 mm; 250 mm
    Weight:Approx 33 kg
    Solid Machine
    Platter:60 mm thick aluminium machined from a single billet
    Feet:Three individually adjustable feet decoupled by Teflon® discs
    Chassis:25 mm strong aluminum body
    Dimensions:380 x 380 mm; 200 mm
    Weight:Approx 30 kg
    Solid Machine Small
    Mat:Natural leather with a 3mm thick acrylic layer
    Dimensions:310 x 310 mm; 200 mm
    Weight:Approx 27 kg
    Solid 111 Metall
    Platter:6 kg full aluminium 30 mm
    Mat:Mat of felt
    Tonearm:WTB303 with high quality phono cartridge
    ControlMicroprocessor controlled power supply
    Chassis:20 mm thick aluminum body
    Dimensions:310 x 310 mm; 190 mm
    Weight:Approx 17 kg
    Solid Wood Referenz
    Chassis:105 mm strong with wenge veneer multiplex plywood panel
    Dimensions:470 x 370 mm; 300 mm
    Weight:Approx 45 kg
    Solid Wood
    The Acoustic Solid Wood is designed in the classical style and is a more robustly constructed version of our Classic Wood model. It uses a heavy 60mm thick aluminium platter running on our precision "zero tolerance" bearing. This is mounted on to a solid 76mm thick MDF plinth, which is finished with a cherry veneer. The platter is string-driven by a separately housed synchronous motor, powered by our microprocessor controlled supply unit. The platter is fitted with a mat made from natural leather, topped with a 5mm thick acrylic layer. The unit is supported on three independently adjustable feet.
    The Acoustic Solid Wood provides further bass extension due to its greater mass. Stereo imaging, resolution of fine detail and dynamics are all to a very high standard. Music is reproduced with a flow that is the essence of the real thing.
    Tonearm:WTB 300
    Chassis:80 mm starke Echtholz furnierte Kirsch-Platte
    Dimensions:470 x 370 mm; 250 mm
    Weight:Approx 35 kg
    Solid Classic Wood
    The Acoustic Solid Classic Wood is designed for those who want a turntable in the more classical style. It uses a heavy 35mm thick aluminium platter running on our precision "zero tolerance" bearing. This is mounted on to a solid 39mm thick MDF plinth, which is finished with a cherry veneer. The platter is string-driven by a separately housed synchronous motor, powered by our microprocessor controlled supply unit.
    As well as being visually very attractive, the Acoustic Solid Classic Wood is a talented musical performer. The bass is solid yet agile, allowing the bass lines in the music to be easily followed. Wide and well-focussed stereo images combined with excellent detail retrieval allow all the instruments in a piece to be followed, even when the music becomes complex and dynamic. Dynamics are themselves well reproduced. All in all, the Acoustic Solid Classic Wood is a very fine turntable.
    Platter:35 mm thick aluminium machined from a single billet
    Mat:Cover mat of felt and a 5 mm thick Plexiglas cover
    Chassis:40 mm strong real wood veneered MDF board
    Dimensions:470 x 340 mm; 190 mm
    Weight:Approx 20 kg
    Solid Wood Round MPX
    Tonearm:WTB 213 with high quality phono cartridge
    Chassis:100 mm strong real wood veneered multiplex plywood panel
    Weight:Approx 17 kg
    Solid Machine Black
    Despite its relatively modest price, the Acoustic Solid Machine Black offers a level of performance that we believe more expensive models from our competitors will struggle to match. This is due to our refusal to compromise on key areas including the use of our own high-precision "zero tolerance" bearing. In addition, it uses a heavy 60mm thick aluminium platter that acts a powerful flywheel to ensure smooth, cogging-free rotation. The use of a separately located motor provides an extremely efficient means of preventing residual motor vibration from reaching the platter and disturbing the stylus. The combination of natural leather and acrylic sheet for the platter mat has been carefully chosen to provide effective damping of any vibration within the record. The Acoustic Solid Machine Black can accommodate up to three tone arms, which should satisfy even the most demanding audiophile.
    The Acoustic Solid Machine Black provides stereo images that are palpable in their reality. The bass is convincing in its extension and timing and this comes together with the other parts of the frequency range to produce an analogue playback that has a feeling of smoothly flowing, just like real music. Listening to a turntable of this quality, it is easy to see why analogue playback is gaining in popularity.
    Tonearm:WTB 211
    Chassis:25 mm thick plexiglas plate
    Weight:Approx 25 kg
    Solid Machine Black
    Tonearm:WTB 211
    Weight:Approx 25 kg
    hauter
    Har kjøpt en spiller allerede. Fungerer supert.
Audio Aktøren
Audio Aktøren sine annonser
Nagra Compact Player nytt produkt fra Nagra
Nagra Compact Player nytt produkt fra Nagra Streamer/DAC NAGRA Compact Player - Nagra High-End Digital Playback, Perfectly Compact The Nagra Compact Player is a complete digital source, while...
Fullt Nagra oppsett
Fullt Nagra oppsett
  • 1
Fullt Nagra oppsett. I oppsettet vil det også være komponenter fra Devore O/96, SME model 6 og Merason Reuss DAC Ønsker du en demonstrasjon ta kontakt for avtale. Terje på 907 62 967 mail...
Qualio Audio IQ30 nyhet hos Audio Aktøren
  • 3
Qualio Audio IQ30 nyhet hos Audio Aktøren Første gang vist i Norge, ønsker du demo er det bare å ta kontakt. Terje på 907 62 967 mail terje@audioakt.no
Mono demo hos Audio Aktøren
Mono demo hos Audio Aktøren trykk på link under Franco Serblin Accordo Essence, Cary amplifiers, Mono recording
Velkommen til Glenghuset i dag og i morgen 22 til 23
  • 2
Velkommen til platemasse/Konsert/HiFi messe i Sarpsborg den 22 til 23 Her er noen bilder fra hva som kommer i dag. Det vill være mange gode tilbud alt fra 10 til 40 % på utvalgte varer. Dette...
Norges premiere Prestige Three Gen 2 i Sarpsborg den 22 til 23 januar
Velkommen til platemasse/Konsert/HiFi messe i Sarpsborg den 22 til 23 Det vill være mange gode tilbud alt fra 10 til 40 % på utvalgte varer. Dette skjer på Glenghuset den 22.01 kl. 14.00-22.00...
