Resultater 1 til 15 av 15
Abonnér på denne artikkelen
  1. Nyhet fra Lumin - U1 Mini
    14 Kommentarer Av Endpoint Audio - 07.09.2018 14:20
    Lumin lanserte i dag nyheten om en rimeligere utgave av sin U1 streamer som kommer uten DAC.
    Denne minimodellen koster 25.990,- og det gis 15% frem til 22 september på denne også.
    Vi gir gode innbyttemuligheter ved oppgradering av din eksisterende Lumin!
    Navn:      41250438_1171221226348911_5460351752022786048_o.jpg
Visninger: 975
Størrelse: 43.2 Kb
    Why LUMIN U1 MINI
    Following the huge success of LUMIN D2, we decided to investigate the possibility of making the LUMIN transport technology similarly accessible.
    The result is a huge specification in a compact package.
    Capable of upsampling and downsampling all the way from 44.1kHz to DSD128 and supporting playback of DSD256, LUMIN U1 MINI matches the U1 in almost every area - except price.
    Transport-only unit combines the best of LUMIN U1 and LUMIN D2
    Identical processor supports DSD256 and 384khz playback
    Quad native clock system for precision timing
    Low noise shielded switching power supply
    5 types of digital audio output including USB
    MQA Decoding
    Resamping to every supported format up to DSD128
    Supports DoP (DSD over PCM) for Optical, Coaxial RCA, Coaxial BNC & AES/EUB SPDIF
    All the usual LUMIN refinements
    From MQA to DSD, FLAC to WAV, LUMIN can play all the high-resolution formats you could ever want
    Native support for TIDAL, Qobuz, Spotify and AirPlay, giving you access to tens of millions of songs
    The unique and intuitive LUMIN App described as "the most convenient interface in existence" by Tinman
    LUMIN programme of continuous development that has seen Roon, MQA, and Spotify support added in 2017 alone.
    Tom Egil
    tom@endpoint-audio.com
    47832922
    Siste redigert av Endpoint Audio; 08.09.2018 kl. 11:29.
  2. Antall kommentarer 14
    Hifi Freak
    Jan 2013
    Tagget i
    3 Innlegg
    Seriøs streamer uten DAC - genialt!
    Aukjsoneres den bort, byr man på den, setter man prisen på den selv, annet? Jeg spør, i og med at den ikke har noen salgspris...
  4. #3
    Æresmedlem gismo's Avatar
    Oct 2007
    Væssia i Grue.
    Tagget i
    0 Innlegg
    Album
    Spennende denne👍🏼😉
  5. #4
    Hifi Freak Distinctive's Avatar
    Dec 2006
    Tagget i
    3 Innlegg
    Album
    Torget
    Absolutt interessant, selv om SMPS bringer frem skeptikeren i meg.
    Noen rykter om en kommende X1 mini over samme lest?
  6. #5
    Bransjemedlem Endpoint Audio's Avatar
    Apr 2013
    Tønsberg
    Tagget i
    0 Innlegg
    Se min butikk
    Klikk her
    Torget
    Nei,
    Lumin er ekstremt dårlig på rykter...
    Det sies at de har en meget god smps, og dette er laget for å få en rimeligere utgave av en high end enhet. Ps delen er i tillegg ekstra skjermet.
  7. #6
    Hifi Freak
    Jan 2013
    Tagget i
    3 Innlegg
    Sitat Sitat fra Endpoint Audio Se Innlegg
    Nei,
    Høres bra ut - alt sammen - er den allikevel uegnet som salgsartikkel for å beheftes med en antagelse av pris?
  8. #7
    Apr 2013
    Tønsberg
    Tagget i
    0 Innlegg
    Se min butikk
    Klikk her
    Torget
    Jeg redigerte innlegget i dag morges til å inneholde pris. Men jeg kan gjenta her at den koster 25990,- men selges med 15% avslag frem til den 22 september.
  9. #8
    Dec 2006
    Tagget i
    3 Innlegg
    Album
    Torget
    Hadde jeg hatt en anstendig DAC (som jeg har) hadde U1 mini absolutt vært på innkjøpslista hvis jeg hadde trengt en god streamer i klasse med den jeg har nå.
    I tillegg tror jeg min A1 må være i nærheten av det mest stabile apparatet jeg noengang har hatt i hus.
    Bortimot fullstendig trøbbelfri uavhengig av oppdateringer.
  10. #9
    Hifi Freak Hi-rex's Avatar
    May 2012
    Etne
    Tagget i
    0 Innlegg
    Torget
    Nu begynder det at ligne noget, der ser fornuftig ut, i realization til Kost, kvalitet, osv.
  11. #10
    Hifi Freak
    Jan 2013
    Tagget i
    3 Innlegg
    Jøss, da snakker vi, sånne summer er betalbart!
    Håper du får en sånn en ut til test, spesielt fordi mange mener god streaming er Naim til rundt 100 lapper eller mer, noe jeg ikke tviler på, men som gjør den du nå viser frem til et mulig svært så spennende alternativ.
  12. #11
    Hifi-interessert
    Oct 2006
    Tagget i
    0 Innlegg
    Og her er et link til første del af et review af Lumin X1
    https://www.monoandstereo.com/2018/0...amer.html#more
    Har selv en T1 , og er meget tilfreds med den , ligesom de gratis opdateringer , såsom opgradering til MQA.
  13. #12
    Sep 2013
    Tagget i
    0 Innlegg
    Hvordan er denne opp imot Lumin D2 lydmessig?
  14. #13
    Apr 2013
    Tønsberg
    Tagget i
    0 Innlegg
    Se min butikk
    Klikk her
    Torget
    Jeg har ikke hørt U1 mini, men U1 har vært i særklasse som streamer. Når de nå har tatt så mye fra U1 og lagt denne inn i en mindre boks og droppet analogdelen så regner jeg med at dette er en killer hvis man allikevel har en god dac og ikke har behov for analog ut.
    D2 er Lumins rimeligste streamer og har en innebygget analogdel og en enkel digital ut mot U1 mini som har 5 digitale utganger og ingen analoge.
    Siste redigert av Endpoint Audio; 10.09.2018 kl. 23:19.
  15. #14
    Jun 2007
    Tagget i
    0 Innlegg
    Hei Endpoint, kan denne tilknyttes intern SSD harddisk eller lese fra minnepinne?
    Er den egnet som "harddisk avspiller" i tillegg til streamer?
  16. #15
    Apr 2013
    Tønsberg
    Tagget i
    0 Innlegg
    Se min butikk
    Klikk her
    Torget
    Hei den kan lese fra ekstern disc som man kobler til USB.
    INPUT:
    Ethernet RJ45 network 1000Base-T Gigabit
    USB storage, flash drive, USB hard disk (FAT32, exFAT, NTFS and EXT2/3)
Skrive Tillatelser
Om Hifisentralen
Følg oss på sosiale medier:
Facebook Twitter RSS Feed
