SPEC RSA-777EX JULETILBUD FRA BEBOP HIFI
Vi spiller julen inn med ett supertilbud på den nye Spec integrerte. Nydelige musikkformidlere med sofistikert klasse D teknologi.
Spec er en av "rørmannen" Rognliens favoritter og dette er meget musikalske og sofistikerte forsterkere. Made in Japan.
Maximum output 100W × 2 (4ohm), 75W × 2 (6ohm), 50W × 2 (8ohm)
Frequency response 10 Hz - 30 kHz ±1dB (6?, 1W)
Harmonic distortion ratio 0.02% (at 1 kHz, 80% output)
Line input terminals XLR input : 1 RCA inputs : 3
Vanlig pris er Kr. 39.900,-. Julepris Kr 29.900,-.
Spec kan du også lytte på hos Gjallarhorn Audio i Heggedal, Asker
www.bebophifi.com
bambi
Smurfeland
Hva er forskjellen på denne og 717EX? Er dette en helt ny modell?
BebopHifi
En remote volumkontroll kan leveres som ekstrautstyr, ingen linjevelger.
BebopHifi
RSA-777EX er en oppgradering av RSA-717EX. Lyden har blitt mer kraftfull, dypere og rikere.
BebopHifi
Ja, samme funksjonalitet som tidligere.
BebopHifi
Kan nok ikke gi deg noe mer utfyllende svar enn følgende sakset fra nettet:
The RSA-777EX has been designed with live music targets in order to reproduce the emotions of a live performance. To this end Spec Corporation has developed a high efficiency Class-D MOS-FET PWM (Pulse-Width Modulation, not Delta-Sigma processing) ‘Counter-Electromotive Force’ circuit that is said to provide superb control of driver movement – high damping factor and monitoring of electro-feedback from the amplifier – and a sound that is reminiscent of good valve amplification but with the control and dynamics of good Class-D designs. Efforts have been made to keep circuit design and the various amplifier stages as free of noise and distortions as possible while the switching frequency has been raked up to 400kHz and well out of the band where noise can be detrimental to the signal.
This Class-D technology is derived from Infineon digital technology specialists. Power rating has been preliminarily quoted as being 50 watts at 8 ohms. Spec Corporation pays attention to vibrational distortions and chassis damping too, with the RSA-777EX having timber panels and specifically-torqued panel screws that are said to ‘tune’ the amplifier to sound more natural.
TomVen
Jar
Av hjemmesidene til Spec ser det ut som om det kun er to integrerte modeller nå; denne og RSA-F33EX. Er dette riktig? Er bakgrunnen at denne er blitt så mye bedre enn 717 at den kan erstatte de gamle «mellommodellene»?
BebopHifi
Modellprogrammet for integrerte forsterkere fra SPEC omfatter følgende.
RSA-777EX,-G3EX og -V1EX i 50W, -M3EX,-M99, -F33EX og -F33R EX i 60W.
Trolig blir -V1 erstattet snart. M99 frigis 20. des. og er en nedskalert modell av F33R.
Gjallarhorn Audio
Heggedal, Asker
Veiledende pris for RSA-M99EX er NOK 105 000,- (med forbehold om prisøkning fra importør p.g.a. kraftig økning av NOK mot JPY). Dagens pris reflekterer en kurs på 7,25, mens den for tiden er 7,8.
BebopHifi
BebopHifi sine annonser
Black Friday tilbud fra BebopHifi
Vi tilbyr på Black Friday følgende produkter til sterkt redusert pris: SPEC platematte for vinylspiller, 30 % rabatt, kr 2250, se egen annonse på Torget. SPEC RSP-AZ9EX, for absoprsjon av...
Ny vinyl tallerkenmatte fra SPEC
  • 3
SPEC AP-UD1- Platematte laget av samme materiale som masterdisc'en. Ved produksjon av vinylplater benyttes en hovedplate, (masterdisc), som utgangspunkt for pressingen av platene. Denne...
Mastersound - Dueundici - Gemini
  • 12
Bebops demosamling av Mastersounds integrerte forsterkere vil befinne seg i Osloområdet i ca 2 uker framover, og demo av disse forsterkerne i et privat godt lytterom tilbys for interesserte...
Nye integrerte forsterkere fra SPEC; RSA-V10/-V11
  • 2
SPEC har fått mange gode tilbakemeldinger på sin modell RSA-M99, også her i Norge. Man ønsket imidlertid å tilby en noe rimeligere variant av denne. Endringene består først og fremst av en liten...
Apertura - franske fristelser hos Bebop Hifi
Det er mange høyttalerprodusenter å velge mellom. Hos Bebop velger vi høyttalere som vi selv mener spiller musikk på en overbevisende måte. Vi startet i 2019 med de franske Apertura. Høyttalerne...
Opplev Apertura Adamante hos Bebop Hifi
Vi har Adamante på permanent utstilling hos oss og kan love lydopplevelser på meget høyt nivå. I Adamante har man klart å kombinere en stor bånddiskant med 2 x 6,5" bass/mellomtoner fullstendig...
