Nos 6N1P-EV ( 6H1П-EB) fra bulk fått nye esker av meg.
Leveres med målinger fra Avo Vcm 163 tester. Sender for kr70.-
1stk kr125.-
2stk matchet kr300.-
4stk matcher kr600.-
A ruggedized 6N1P called 6N1P-ev by former Voskhod Factory, Russia c.1970s. Famous ‘Voskhod Rockets’ made to Military Specification including nickel plated pins for good conductivity and gold grid for improved sound. Life expectancy 5000hrs. A well made vacuum tube which will deliver excellent results and reliability. They come in their original ‘Rocket Logo ‘ boxes!
Kopi: https://www.audiozomba.com/product/6n1p-vacuum-tubes/
The Russian 6N1P preamp tube is a small signal dual triode intended for use as a line level amplifier or driver in high quality audio amplifiers. These vacuum tubes are often found relabeled by Sovtek or Svetlana. Except for higher heater current, the 6N1P is similar to 6DJ8, ECC88 or 6922 types and may substitute for these types in some high level audio applications.
Check with your equipment manufacturer before using this tube as a sub for these types.
Kopi: https://www.thetubestore.com/russia...weM2ZbjyWWdijs1hE7Hto_nh5U9i2-sY_vq2rg3eUgG0j
1stk kr125.-
- Originalemballasje
- Nei
- Orig. kvittering
- Nei
- Forsendelse
- Kan sendes
