Abrahamsen A-DACII kun brukt et par uker. Fremstår som ny. Selges med original emballasje. Frakt kommer i så fall i tillegg.
Nypris var 1690 kroner på tilbud. På http://www.store.abrahamsenaudio.no/ koster den 1990 kroner.
The A-DACII is a digital converter with USB and Spdif/coax and Toshlink inputs. The digital signal is up sampled from 16bit to 24bit and the frequency response is increased from 44.1 KHz to 192 KHz. This will reduce the noise floor by more than 10dB so that music signal previously masked by the noise now will stand out and amplified, and high frequency overtones will be reproduced without any distortion.
To achieve maximum cancelation of distortion and low frequency noise, the amplifier stage is fully balanced from input to output. To further reduce the distortion and improve linearity, all transistors are matched. This reduce the need for high negative feedback and thereby avoid the traditional "transistor sound".
Ta kontakt på pm.
Ta kontakt på pm.
