Endpoint Audio
Butikk Absolare Bybee Filter Solgt
Denne annonsen er utgått.
Strømfiltere
Selges
Tilstand
Brukt
Utløpsdato
Fylke/land
Vestfold
Pris
Kr 18.000
Kjøpt av
*RBJ*
Annonse beskrivelse
Annonse nummer: 86660
Absolare bybee nettfilter i sort skinn og aluminium. 1 1/2 år gammelt og brukt i eget oppsett.
Nypris 57.500,- selges kr 18.000,-
6 oyaide uttak.
info om produktet:
Absolare?s unique strategic partnership with Bybee Technologies, USA has brought together Absolare?s expertise in metallurgy and resonance control with Jack Bybee?s groundbreaking Quantum Purification technology. The result is a product of unprecedented performance. The Absolare Bybee Purifier is a state of the art electrical mains distribution device which will actually ?purify? the mains. Without compromising current flow, this purified AC power perfectly preserves the full gamut of dynamics and harmonics in music. If we consider the analogy of the human body, a perfectly balanced audio system allows unhindered transmission of electrical power through the system?s chain of components in the same manner blood flows easily within a healthy body?s circulatory system. Absolare Bybee Purifiers differ from all other power ?filters? or ?conditioners? by purifying the system?s ?blood? using jointly developed proprietary versions of Bybee?s pioneering quantum-level technology. With any playback system, the quality of the final musical (or visual) experience depends on maintaining absolute fidelity of the signal?s transmission. As the complex dynamic flow of electrons interact within the conductive materials of cables and circuits, very low-level (quantum) noises are generated. As quantum noise energy accumulates in the propagating signal, low-level details pertaining to ambience, soundstage, timbre, dynamics, color fidelity and image resolution are obscured, robbing the presentation of vividness and a sense of life and vitality. As with all Absolare equipment, each component is of the highest quality and critically selected for specific applications. Internally wired with actual Echole Obsession SIGNATURE Powercords and fitted with customized versions of the highest grade of AC sockets from Oyaide in Japan, Absolare also incorporates customised Mundorf silver/gold capacitors to further improve the current. Specially developed composites critically attenuate the spectrum of resonance of the Bybee Modules and all other internal components, perfectly preserving the music?s dynamic and harmonic complexities.
Type: Passive Electrical Mains Distribution Device.
Application: The device is designed supply an entire audio system, including all types of power amplifiers.
AC Input: The device can be used with 110-120 Volt AC & 220-240 Volt AC electrical mains supply. There is a 15A circuit breaker.
AC Outputs: Available in two versions both with six outlets ? (a) six European Schuko AC outlets or (b) three sets of duplex US AC outlets.
Components: Oyaide Silver/Palladium coated IEC receptacle. Oyaide Silver/Palladium coated AC outlets. Echole Obsession Signature powercord internal wiring.. Jack Bybee designed non-current limiting EMI/RFI filtering devices. Mundorf custom SilverGold 800AC capacitors. Absolare proprietory resonance control composite treating all
  • 6 x Custom-Polished Palladium over Silver Oyaide Outlets (US or SCHUKO)
  • Non-Current Limiting Passive design
  • 110 / 240V compatibility
  • No-inductor throughout the design
  • Actual Echole Obsession Signature Powercords employed
  • Dimensions: 48.0 x 39 x 10.0 cm (WxDxH), excl. feet
  • Weight: 13.0 Kg
Endpoint Audio
Torget karakterer
Vurderinger (38)
Andre annonser av Endpoint Audio
