Audio Agenten
Butikk Aerial Acoustics 6T
Denne annonsen er utgått.
Gulvhøyttalere
Selges
Tilstand
Ny
Utløpsdato
Fylke/land
Sør-Trøndelag
Pris
Kr 69.000
Annonse beskrivelse
Annonse nummer: 230705
På lager i svart piano.
Test: https://www.stereophile.com/content/new-6t-aerial-acoustics
Frequency Response 35 Hz to 25 kHz 2 dB, -6 dB at 30 Hz
Sensitivity 90 dB for 2.83 volts at 1 meter on axis
Impedance 4 ohms, 3 ohms minimum, low reactance
Power Requirements 25 watts minimum, >50 recommended
Woofers Dual 5.9? (150 mm) with cast magnesium frames, special papyrus blend cone. copper pole sleeve, dual magnets, 1.25? coil, long and linear Xmax
Midrange 4.8? (123 mm) with cast magnesium frame, special papyrus blend cone. copper pole sleeve, dual magnets, 1.00? copper clad aluminum coil
Tweeter 1? (25 mm) with thick machined aluminum plate, soft ring-dome design with machined wave guide, dual-magnets, 1.00? coil, copper pole sleeve
Crossover Fourth order acoustic Linkwitz-Riley, 600 Hz and 4,000 Hz crossover frequencies, 2 physically separate networks
Connections Four gold-plated binding posts with included jumpers, bi-wire and bi-amp capable
Cabinet 6 Layer laminated, curved, stressed MDF walls, 3 full-size braces, tongue & groove joints, 2 Layer curved, damped baffle, architectural veneers
Grille Cloth-covered curved steel with large hexagonal windows, 8 Pairs of strong hidden Neodymium grille magnets
Dimensions HWD 43.5 x 7.7 x 13.2? (1105 x 195 x 335 mm) height Includes Base and 1? spikes
Weight Each 65 lbs (30 kg) unpacked – 91 lbs (41 kg) packed
Besøk gjerne www.audioagenten.com
Originalemballasje
Ja
Orig. kvittering
Ja
Forsendelse
Avtales nærmere
Audio Agenten
Torget karakterer
Vurderinger
Andre annonser av Audio Agenten
