Audio Agenten
Butikk Aerial Acoustics 7T
Gulvhøyttalere
Selges
Tilstand
Ny
Utløpsdato
Fylke/land
Sør-Trøndelag
Pris
Kr 109.500
Annonse beskrivelse
Annonse nummer: 230704
På lager i svart piano.
Frequency Response 28Hz to 25kHz 2dB, -6dB at 23Hz
Dispersion 30Hz to 15kHz +0, -3dB from axial response 45 degree horizontal measurement window
Sensitivity 89dB for 2.83 volts at 1 meter on axis
Impedance 4? nominal, 3? minimum, low reactance
Power Requirement 25 watts minimum, 100 or more recommended
Woofers Twin 7.1? (180mm) with cast magnesium frame, rigid bilaminate composite cones, large magnets, 1.5? coils, long and linear Xmax
Midrange 5.9? (150mm) with cast magnesium frame, special Papyrus blend cone, copper pole sleeve, dual magnets1.25? coil, long and linear Xmax
Tweeter 1.0? (25mm) with thick machined aluminum plate, soft ring-dome design with machined wave guide, dual magnets, 1.0? coil, copper pole sleeve
Crossovers Fourth order acoustic Linkwitz-Riley at 400 Hz and 3,000 Hz crossover frequencies, 2 physically separate networks on glass-epoxy PCBs, bi-wirable and biampable, high-purity copper wiring and silver solder, premium passive components
Cabinet 9 layer laminated, curved, stressed MDF walls, 7 interlocked full-size braces, tongue and groove joints, 2-piece curved and damped baffle, architectural veneers
Finishes Gloss Rosenut, Nero Metallic Black
Grille Cloth covered curved steel with hexagonal windows, 8 Neodymium magnets, no visible mounting hardware
Connections Four gold-plated binding posts with copper jumpers, bi-wire and bi-amp capable
Included Accessories Nero metallic black base, adjustable feet, adjustable spikes, floor protectors
Dimensions HWD 44.5 × 9.7 × 15.3? (1130 × 245 × 390mm)
Weight Each (44kg) – (70kg) packed
Besøk gjerne www.audioagenten.com
Originalemballasje
Ja
Orig. kvittering
Ja
Forsendelse
Avtales nærmere
Audio Agenten
Torget karakterer
Vurderinger
Andre annonser av Audio Agenten
