Vi selger for kunde en Audia Flight FLS10 i svart finish med både DAC og phono modul.
Forsterkeren er kun 5mnd gml og fremstår som ny.
Nypris Audia Flight FLS10 97.000.-
DAC modul 18.900.-
Phono modul 12.500.-
Selges for 89.000.-
Preliminary Technical Data
Output power per channel Wrms: 200/380/700 (8/4/2 ohm)
Inputs: 3 unbalanced (RCA), 2 balanced (XLR)
Outputs: 1 unbalanced (RCA), 1 balanced (XLR), 1 REC unbalanced (RCA)
Gain range: -90dB / +10dB
Gain resolution: 0,5dB
Frequency response (-3dB): 0,3 Hz ÷ 500 KHz
THD: < 0,05 %
S/N Ratio: 110 dB
Input impedance: 47 Kohm
Damping factor (on 8 ohm): > 650
Main voltage AC (50-60Hz): 100, 110-115, 220-230, 240 V
Stand-by power consumption: less than 1 W
Power consumption (200W RMS @ 8 Ohm both channels)840W
Dimensions and weight450x180x440mm (W x H x D) - 36kg
Shipping dimensions and weight575x280x545mm (W x H x D) - 44kg
JWK Audio/Sound of heaven
Tlf:+47 464 29 861
E-mail: kontakt@soundofheaven.as
Hjemmeside: www.soundofheaven.as
DAC modul 18.900.-
Selges for 89.000.-
THD: < 0,05 %
S/N Ratio: 110 dB
Tlf:+47 464 29 861
- Originalemballasje
- Ja
- Orig. kvittering
- Ja
- Forsendelse
- Avtales nærmere
