Audio Pro Blue Diamond V2
ar for salg er par Blue Diamond V2.
Man kan se et par plasser at folien har sluppet taket
Fungerer 100% som de skal.
på den ene ht. Mulig løsning er å sprøyte inn lim.
Hentes i Stavangerområdet.
Åpen for bud.
Kan selvsagt sende bilder, men disse må uansett hentes, så de kan høres og sees hos meg.
Blue Diamond V.2 is a delicate fusion between the purity
of Black Diamond and the deep bass of an ace-bass
subwoofer. With a built-in 175W ace-bass amplifier and a
10? long-throw woofer, power is well taken care of even
for home theater. Blue Diamond has its given place in a
serious HiFi or home theater system, and its elegant design and high-gloss finish make it welcome in any home.
In a home theater equipped with a pair of Blue Diamond
V.2, there is no need for an additional subwoofer. The
built-in subwoofer takes care of both your front channel?s
bass and the dedicated subwoofer channel in 5.1 digital
sound through the separate line-in input and the adjustable
volume level.
BLUE DIAMOND V.2
Type: Floorstanding speaker, 2-way, bass reflex with
built-in 175W ace-bass® subwoofer
Tweeter: 1?, soft dome, shielded
Midrange/woofer: 6 1/2? coated, shielded
Subwoofer: 10?, long-throw
Frequency range: 22-25.000 Hz
Impedance: 4 ohm
Crossover frequency: 75 Hz/3.200 Hz, 6/18 dB
Amplifier requirement: 25 - 150W
Lo-pass filter: 75 Hz, 24 dB/octave, electronic Linkwitz
Riley filter, 4:th order
Dimensions (WxHxD): 190x1045x380 mm
Weight: 30,5 kg/piece
Adjustments: Auto standby, separate controls for level
and line-input
Connectors: Line and speaker level input, heavy duty
gold plated binding post
Cabinet: MDF
Finish: High-gloss laquer foil
Colors: Black
Åpen for bud.
volume level.
BLUE DIAMOND V.2
Impedance: 4 ohm
and line-input
Cabinet: MDF
Colors: Black
