Audio Research SP-4 High Def Solgt
Denne annonsen er utgått.
Forforsterker
Selges
Tilstand
Brukt
Utløpsdato
Fylke/land
Telemark
Pris
Kr 4.000
Kjøpt av
lille hiawata
Annonse beskrivelse
Annonse nummer: 94400
Audio Research SP-4 High Definition Preamplifier selges, S# 67102042.
Denne er i mint condition og fremstår så godt som ny, og i tradisjonell 70-tall 'tank build' fra ARC :)
Ikke mange å finne i denne tilstand, og dette er BILLIG!
Vedlagte bilder er av salgsobjekt.
Sakset fra ARC beskrivelse:
Description
The SP-4 preamplifier was designed around the Analog Module which acts as a 'super tube' because it takes the best qualities we see in the vacuum tube much closer to the theoretical ideal.
The SP-4 surpasses our vacuum tube preamplifier in the most important areas. It has increased musical depth and definition with a smoothness that will satisfy any vacuum tube enthusiast.
Specifications
Frequency response(High level): 1Hz to 100kHz
Total harmonic distortion: 0.005% @ 2V RMS
Gain: 36dB (MM), 24dB (line)
En tilfeldig plukket anmeldelse fra 2000:
"There?s not much to say, other than accolades and praise.
My SP-4 was built nearly 15 years ago and performs as if it
came out of the box yesterday. It produces a soundfield that will drop your jaw. This is a full feature solid-state preamp, with dual pre-outs, fabulous dual phono inputs, and phono head amp, tuner, dual auxiliary inputs, and dual tape loops with monitoring, and dubbing (yes a balance control too), tone controls, tone defeat, a stereo/mono reverse selector, and a subsonic filter. Proportion, presentation, aesthetics, user-friendly controls and labeling are benchmarks of the entire line of AR preamps, in my humble opinion. I'm not going to mince words here: the AR SP-4 is one the best solid-state preamps I've heard. It's balance of sonic virtues, operating convenience; build quality leaves nothing to be desired.
If you find it on the used market (in good condition) buy it asap. Five stars! ! !"
torh1
Fersking
Torget karakterer
Vurderinger (1)
