Audio Agenten
Butikk Audio Solutions Figaro L
Gulvhøyttalere
Selges
Tilstand
Ny
Utløpsdato
Fylke/land
Sør-Trøndelag
Pris
Kr 91.000
Annonse beskrivelse
Annonse nummer: 230701
På lager i svart.
Dimensions (HxWxD) : 1230mm x 356mm x 618mm; 48.4 x 14 x 24.3in
Weight : 70 kg/154 lbs each
Shipping weight : 78 kg/172 lbs each
Sensitivity : 92 dB @ 2.83V 1m
Nominal power handling : 200 W rms
Maximum unclipped power handling : 400 W;
Impedance : nominal 4,0 ohms;
Crossover frequency : 400 Hz; 4000 Hz
Frequency response (in-room environment) : 25-25000 Hz
Drivers : 2,5cm silk dome tweeter, two 15.2cm ER paper cone mids, two 23.3cm ER paper bass drivers
Besøk gjerne www.audioagenten.com
Originalemballasje
Ja
Orig. kvittering
Ja
Forsendelse
Avtales nærmere
Audio Agenten
Torget karakterer
Vurderinger
Andre annonser av Audio Agenten
