Audio Agenten
Butikk Audio Solutions Overture O305F
Gulvhøyttalere
Selges
Tilstand
Ny
Utløpsdato
Fylke/land
Sør-Trøndelag
Pris
Kr 49.500
Annonse beskrivelse
Annonse nummer: 230703
På lager i svart
Dimensions (HxWxD) : 1110mm x 250mm (421mm with feet) x 390mm; 43.7 x 9.9 (16.6) x 15.4 in
Weight : 39 kg/88 lbs each
Shipping weight : 43 kg/106 lbs each
Sensitivity : 91 dB @ 2.83V 1m
Nominal power handling : 160 W rms
Maximum unclipped power handling : 320 W;
Impedance : nominal 4,0 ohms
Crossover frequency : 500 Hz; 3000 Hz
Frequency response (in-room environment) : 33-26000 Hz
Drivers : 2,5 cm silk dome tweeter, 15.2 cm ER paper cone mid, two 18.3 cm ER paper cone bass drivers
Besøk gjerne www.audioagenten.com
Originalemballasje
Ja
Orig. kvittering
Ja
Forsendelse
Avtales nærmere
Audio Agenten
Torget karakterer
Vurderinger
Andre annonser av Audio Agenten
