Kommer inn for demo i uke 10.
Bygget opp med kabinett i kabinett. Justerbart delefilter som gir 3 forskjellige lytteopplevelser. WBT nextgen terminaler. Mini hornlading.
Dimensions (HxWxD) : 1240mm x 444mm x 621mm; 48.8 x 17.5 x 24.5in
Dimensions without plinth (HxWxD) : 1205mm x 319mm x 542mm; 47.4 x 12.6 x 21.3in
Weight : 75 kg/165 lbs each
Shipping weight : 120 kg/240 lbs each
Sensitivity : 92 dB @ 2.83V 1m
Nominal power handling : 170 W rms
Maximum unclipped power handling : 340 W;
Impedance : nominal 4,0 ohms
Crossover frequency : 500 Hz; 7000 Hz
Frequency response (in-room environment) : 25-30000 Hz
Award
Mono and Stereo Upper Echelon Class 2020 Award
Mono and Stereo "Best of 2020" Award
Drivers : 3cm silk dome tweeter, 16.5cm Hard Pulp paper cone mid, two 19cm Hard Pulp cone bass drivers
Best of High End 2019 award
AVShowrooms Gold Show 2019 Award
Positive Feedback (RMAF) 2019 Award
AVShowrooms Best Sound 2020
Award
- Originalemballasje
- Ja
- Orig. kvittering
- Ja
- Forsendelse
- Kan sendes
