Selger en så å si ubrukt AT (spilletid 30 t.) pga. kjøp av ny pick-up. Fantastisk picup til prisen
Nypris 4700,-
[FONT=&]Features[/FONT]
[FONT=&]Improved boron pure tapered cantilever and lighter vibration system. [/FONT]
[FONT=&]High performance and lifelong Micro linear stylus(average 1000hours) . [/FONT]
[FONT=&]High separation and wide response dual moving coil. [/FONT]
[FONT=&]Anti-vibration designed Potassium titanate mixed rigid synthetic resin VC mold. [/FONT]
[FONT=&]High rigidly body was designed aluminum alloy based rigid resin and anti-parasitic resonance.
Specifications [/FONT]
[FONT=&]Model Type: MC [/FONT]
[FONT=&]Playback frequency range: 15 - 50,000 Hz [/FONT]
[FONT=&]Output Voltage: 0.3mV (1 kHz, 3.54cm/sec.) [/FONT]
[FONT=&]Channel: 30dB (1 kHz) [/FONT]
[FONT=&]Output Balance: 0.5dB (1 kHz) [/FONT]
[FONT=&]Needle pressure: 1.8 - 2.2g (2.0g standard) [/FONT]
[FONT=&]Coil impedance: 10 ohm (1 kHz) [/FONT]
[FONT=&]DC resistance: 10 ohm [/FONT]
[FONT=&]Load resistance: Above 100 ohm [/FONT]
[FONT=&]Coil: 22[/FONT][FONT=&]?[/FONT][FONT=&]H (1kHz) [/FONT]
[FONT=&]Static compliance: 40 x 10-6cm/dyne [/FONT]
[FONT=&]Dynamic compliance: 10 x 10-6cm/dyne (100Hz) [/FONT]
[FONT=&]Needle shape: Micro Linear [/FONT]
[FONT=&]Vertical Tracking Angle: 23 degree [/FONT]
[FONT=&]Dimensions: H16 x W16.6 x D26.5mm [/FONT]
[FONT=&]Mass: 6.9g[/FONT]
Nypris 4700,-
