Audiomachina CRM and CRS loudspeakers have been designed to disappear, leaving you only with the beauty of music. They are unlike anything that you have seen or heard before.
Sculpted from blocks of solid aerospace aluminium alloy, into smooth and gently flowing geometries. With the finest drivers, connected using only the highest quality first-order crossovers, or wherever possible use no crossover parts at all. They employ the best drivers and custom electronics available, and the resulting sound is incredibly detailed and completely neutral.
The result of all this painstaking craftsmanship - the only speaker in the world that a lover of live music should own.
It's shocking how good these speakers.
The CRS is an active powered subwoofer with internal 500W amplifier.
They are in excellent condition and work perfectly. They'll ship in the original boxes. The grills are like new because I never used them. Price is firm - these speakers go up for sale very rarely, and you won't find a better price than this.
Audiomachina CRM & CRS with custom designed aluminium stands – rrp £24,000.00
This a Private Sale, there is no return, no guarantee and no exchange. The goods are sold under exclusion of any warranty. Shipping must be organized by buyer.
Specifications
Compact Reference Monitor (CRM)
Type: 2-way sealed-box reference mini-monitor
Construction: Full SSA (Solid Slab Aluminum)
Frequency Response: 45-20kHz
Sensitivity: 84dB @ 8 Ohms, benign phase
Drivers: 6″ (15cm) mid-bass, 1″ (2.5cm) tweeter
Crossover: Purist, Ti technology, 3kHz
Dimensions: 12″H x 8″W x 6″D (30 x 20 x 15 cm)
Weight: 27 lbs (12kg) each
Recommended Amplifier: 20-100 WPC @ 8 Ohms
Compact Reference Subwoofer (CRS)
Type: Active powered reference subwoofer
Frequency Response: 15-100Hz
Driver: 10″ (26cm) ultra-long-throw subwoofer
Filter: 100% analog active filter, adjustable frequency/level
Amplifier: 500W ICEpower, internal
Dimensions: 14″H x 12″W x 6″D (35 x 30 x 15 cm)
Weight: 50 lbs (23kg) each.
Specifications
- Originalemballasje
- Ja
- Orig. kvittering
- Ja
- Forsendelse
- Kan sendes
