6mnd. gammel Audion Phono Pre. for MM pick up selges. Strøken, kvittering, original emballasje. Nypris 6500,- SELGES for 4700,- med frakt. IKKE oppkrav, kun forskudd.
Henv. PM
Morten
!!!!!!!!!!!!!!!!SOLGT!!!!!!!!!!!!!!!
The soundstage is believeably big, and really it is up to the recordings capabilities to shine through. Musicians are convincingly placed. Noise level is pitch black. Roll off in both directions is seamless. Resolution is astounding, with absolutely convincing depth even at very low listening levels. It does not beautify bad records, but it gives sparkle to great recordings, and preserves tonality, rhythm and sense of space. We refer to this as being neutral, but not sterile or warm or tubelike.
Amplifier matching
This moving magnet phono stage is best suited for use with standard or low output moving magnet cartridges. Ideally matched with our range of Proton cables. The phono stage is easily matched with most cartridges and being an active stage ir does not need such close matching as you would with a transformer based product. Upgrade options are available for this model, see upgrade options at end. Can and has been made in hard wired mono_blocks
Quality both inside and out
The MM phono stage is an active class A stage using a transformer less design, which means matching is very easy. It is far less critical of capacitance, resistance, impedance, inductance or reactance matching that transformer couple RIAA stages normally need.
The Phono MM stage uses NOS Russian 6H23N tubes, it also has a ground lift switch at the rear to assist in resolving grounding issues by floating the ground internally above mains ground. We recommend our Proton cables with this phono stage.
Henv. PM
Morten
Amplifier matching
Sensitivity Ref ? 0dbV | 2.0mV MM | Phase | Correct |
Distortion @ 1V | <0.015% No Feedback | Noise CCIR) | <80 db |
Frequency Response: | 11 ? 185KHz ±1 db RIAA | Signal to Noise: | >70 db |
Inputs: | 2 x 1 Phono MM | Outputs | 2 x 1 Main Out |
Consumption: | 12 Watts | Tubes: | 2 x 6922 or E88CC |
Size - | 42cm deep, 23cm tall and 16cm tall - Less tubes | Weight | 6kgs |
Fuses - | Power 500mA / 240V | Warranty - | 2 years - tubes 6 |
