Er litt nyskjerrig på denne. Har du en du kan kvitte deg med, ta gjerne kontakt.
Jørgen
SPECIFICATIONS:
Jørgen
SPECIFICATIONS:
RIAA equalization | +/- .5 dB |
Integrated rumble filter | 10 Hz (-1 dB @ 20 Hz) |
Gain at 1 kHz | 1,280 (62 dB) |
Crosstalk | Below measuring range |
Signal to noise ratio (.5 mV, 0 ohm) | 82 dB (IHF “A”) |
Maximum input voltage | 5 mV (1 kHz) |
Input impedance | 22k ohms |
