Et par Med Beyma 15XA38Nd såvidt utpakket og prøvd til salgs
Veldig bra coax elementer med orginale passive filtre .
Avshop har en konstruksjon med disse.
Koster 5800.-pr stk uten filter .
https://www.avshop.no/product/beyma-15xa38nd-coaxial-driver/
https://en.toutlehautparleur.com/crossover-beyma-fd2xa-2-ways-1800-hz.html
https://en.toutlehautparleur.com/coaxial-speaker-beyma-15xa38nd-8-16-ohm-15-inch.html
Har org esker så disse kan sendes for 300.- i porto.
TECHNICAL SPECIFICATIONS
Nominal impedance LF/HF 8/16 ohm
HF diaphragm ref. 5MCP756
LF Recone kit ref. 5M15XA388
Nominal diameter 380 mm 15 in
Minimum impedance LF/HF 8.4 / 12.6 ohm
Frequency range 40-20000 Hz
Power capacity LF/HF 350/90 W AES Program power LF/HF 700/180 w
Sensitivity LF/HF 99/105 2.83 @ 1 m @ 2π
Recom. crossover frequency 1.5 kHz or higher (12dB/oct min slope)
Voice coil diameter LF/HF 101.6/72.4 mm - 4/2.85 in Dispersion (conical) 80º
BL factor 20.4 N/A
Moving mass 0.082 kg
Winding length 16 mm
Xdamage pp 28 mm
PARAMETERS THIELE & SMALL
Fs 38 Hz
Re 6.7 ohm
Qms 6.4
Qes 0.31
Qts 0.3
Vas 238 l
Cms 217 µm / N Rms 3 kg / s
Efficiency % 3.9 Sd 0.088 m²
Xmax 6 mm
Vd 528 cm³
Le @1 kHz 1 mH
BL factor 20.4 N/A
Xdamage pp 28 mm
Fs 38 Hz
Re 6.7 ohm
Qms 6.4
Qes 0.31
Qts 0.3
Vas 238 l
Xmax 6 mm
Vd 528 cm³
Le @1 kHz 1 mH
- Originalemballasje
- Ja
- Orig. kvittering
- Nei
- Forsendelse
- Kan sendes
