Blacnote dac 30 selges for kunde. En voksen eier og den fremstår som ny.
Kjøpt brukt hos PM audio 01.12.2014. Kjøpt med nye Golden Dragon 12ax7 rør, brukt ca 600 timer.
Kostet ny kr 35900 og selges for kun 8900 / akseptabelt bud.
Alle som oppgir fullt navn og telefonnummer på sine henvendelser, får svar.
Den spiller utmerket med den behagelige og oppløste, gjennomsiktige rørlyden, uten hardhet!
Her kan du skaffe deg en topp dac meget rimelig!
The DAC30 Back Panel
IEC Plug & Fuse:
- 100-240 Volt - 50/60 Hz with 1 A fuse
Digital Input:
-(2) two High-Speed USB 480Mb/s port
-(4) Four Coaxial RCA 75ohm Digital S/PDIF compliance
-(1) Optical Tos-Link
-(1) XLR 110ohm AES/EBU AES3
Digital Output:
- (1) Coaxial RCA Digital S/PDIF compliant
Analog Output:
- Left and Right RCA Stereo Unbalanced Analog Output
- Left and Right XLR Stereo Balanced Analog Output
Other Special Features:
- Triple Power Supply super linear set up
- Convenient 240mm wide chassis
- Front panel based on the same Blacknote family compact design features a display shows the menu option selected
- Remote and Volume control to let it use as a direct source/player directly
- Class A Tube output stage
Notes: The DAC30 can convert the signal directly from any computer playing native file in any resolution up to 24bit and 192KHz.
High Speed USB DAC and DAC30 Technical Specifications
SAMPLE RATE SUPPORTED: All up to 192KHz
ANALOG OUTPUT: Stereo RCA & XLR Balanced
AUDIO FORMAT SUPPORTED: All the computer Players used formats
FREQUENCY RESPONSE: 20Hz - 20KHz @ +/- 0,3dB
ANALOG OUTPUT LEVEL: 2 volt RMS
THD (Total Harmonic Distortion): 0,05% TUBE
SIGNAL-NOISE: 90dB TUBE
DYNAMIC RESPONSE: 125dB
POWER SUPPLY: 100/260Volt 50/60Hz Super Linear
POWER CONSUMPTION: 60watt TUBE
DIMENSIONS: 9 inches Wide x 5 inches High x 16 inches Deep
WEIGHT: 18 lbs.
Kan sendes på kjøpers regning og ansvar meget forsvarlig innpakket i original emballasje!
Til andre gode tilbud.
IEC Plug & Fuse:
Digital Input:
Digital Output:
Analog Output:
WEIGHT: 18 lbs.
