Endpoint Audio
Butikk Bricasti M3 DAC/Streamer/HT forsterker. Alt i ett tilbud.
D/a konverter
Selges
Tilstand
Ny
Utløpsdato
Fylke/land
Vestfold
Pris
Kr 79.990
Annonse beskrivelse
Annonse nummer: 232665
HiFi News - Outstanding Product!
Bricasti’s M3 er en ekte High End DAC/Streamer/Hodetelefonforsterker i én boks.
Veiledende pris med alt inkl er 79990,-
Sjekk ut flere DAC’er her:
Denne gjør alt, og som med alle Bricasti produkter så er alt perfeksjonert.
"Whether you stream your music from Roon, have a big CD library and are looking to trial a new transport, or just enjoy connecting a laptop and listening over headphones, the Bricasti M3 is worth saving for."
-Christopher Breunig
Info fra Bricasti:
Exceptional performance and value
The M3 offers an incredible array of performance in a more affordable price class. Highlights include two fully differential conversion channels, separate conversion for PCM and native DSD, and a balanced analog level control circuit, making the M3 suitable for all applications.
Powerful Architecture
The M3 utilizes two independent linear power supplies for the analog and digital processing to insure low noise and superior isolation. A newly designed chassis made from robust CNC milled aluminum in sections insures superior thermal characteristics, excellent vibrational damping and shielding from RF.
Re-creating sound is an art and a science
The M3’s digital design employs precision DDS clocking that lowers jitter to extremely low levels, insuring a pure digital signal path without the use sample of rate converters, this combined with superior digital filter design, and Native DSD conversion yields a state of the art digital audio path. The M3’s high speed low distortion analog path features a bypass-able preamp class analog level control allowing the M3 to be used to drive power amps directly, with no bit loss for optimal analog performance.
M3H:
Fully differential headphone option
The M3H was designed for the discerning headphone aficionado in mind. Featuring independent analog amplifiers for plus and minus on the XLR output to create a fully balanced headphone system with exceptional performance.
Features
Manual
Buy
Digital Inputs XLR: AES/EBU 24 bit Single Wire, RCA: SPDIF, Optical: Toslink 44.1- 96k, USB 2, RJ45: Ethernet (Optional)
Sample Rates AES, SPDIF 44.1 kHz, to, 192khz, DSD 64fs as DoP
Sample Rates USB 44.1 kHz, to, 384kHz, DSD 64fs 128Fs 256Fs Native and DoP
Sample Rates Ethernet 44.1 kHz, to, 384kHz, DSD 64fs, 128Fs Native
Jitter 8 psec @ 48k / 6psec @ 96k
Balanced Analog Outputs XLR balanced (pin 2 hot)
D/A Conversion PCM 24 bit delta sigma 8x oversampling, NDSD pure 1 bit conversion for DSD
Impedance 40 ohm
Output Level @ 0 db front panel +14.3 dbm 4 db RMS ( bypass mode)
Frequency Response @44.1k 10 hz- 20 kHz +0dB, -.2 dB
Dynamic Range >120dB A-Weighted
THD+N @ 1k .0008% @ 0dbfs / .0004% @-30dbfs
Unbalanced Analog Outputs RCA
Impedance 40 ohm
Output level @ 0 db front panel = +4db 2V rms
Frequency Response @ 44.1k 10 hz- 20 kHz -.2 dB
General Specifications
Finish Anodized Aluminum
Dimensions: 14” x 11.25“ x 2.5”
Weight: 10 lbs
Shipping Weight: 15 lbs
Mains Voltage: 100, 120, 220, 240 VAC, 50 Hz – 60 Hz factory set
Trigger in/out: TRS mini jack, Tip ground, Sleeve 5V
Power consumption: 20 Watts
Warranty parts and labor: 2 years non-transferable
Originalemballasje
Ja
Orig. kvittering
Ja
Forsendelse
Kan sendes
Endpoint Audio
Torget karakterer
Vurderinger (40)
Andre annonser av Endpoint Audio
