Fullbalansert Headamp fra Burson!
Conductor 3 leverer 7.5 Watt @ 16 Ohm, Ampen driver alt av hodetelefoner. -
Både DAC delen og USB mottakeren har blitt oppgradert. DACen er basert på 2 x Sabre ESS9038Pro ( 140dB Dynamisk rekkevidde,THD+N (0.0004%), dual mono design ) og 7 digitale filtre er tilgjengelige for å tune lyden.
Burson Conductor REF 3X låter åpent, detaljert og musikalsk engasjerende.
The Best DAC / Headphone Amp / Preamp
The Conductor 3X is for those who go all the way. Fully balanced with one DAC chip per channel. Pure Class-A and fully discrete with top quality components throughout, including Neutrik XLR connectors, the C3X is the perfect command centre for any XLR audio systems.
The C3X achieves an even lower signal-to-noise ratio, revealing amazing microdynamics, the stuff that makes music magical. Furthermore, by going fully balanced, the C3X achieves ultra-low output impedance, making it the perfect preamp for any power amplifier.
Its balanced headphone output delivers 7.5W per channel while its half-the-power single-ended output is still powerful enough to drive any headphones with ease.
Advanced Digital
The SABRE32/ESS9038Q2M DAC and XMOS USB receiver chips are the most advanced and expensive in the industry. There are two ESS9038 DAC chips in our C3 Reference and its USB receiver comes with customised driver by Thesycon, Germany. The result is unsurpassed processing power, perfectly playing back DSD512 and 38bit/786khz audio. The C3 Reference also features a Bluetooth 5.0 receiver Qualcomm/CSR8675 [+] with aptX HD audio codec. It pushes Bluetooth playback beyond CD quality and ease of use to the highest level.
Max Power X 5
Max Current Power Supply (MCPS) [+] raises voltage frequency from 50Hz to 170kHz, pushing noise beyond human hearing. Its low impedance ensures abundant and instant energy for output transistors. The C3 Reference uses 5 sets of MCPS: Which means, Display/Functionality, DAC, analouge left and analouge right are all separately powered.
The Cool Case
Let’s face it, most audio equipment cases are ugly and impractical. They usually have visible screws everywhere, sharp corners and boring colours. Class-A amplifiers even have finger cutting heat-sinks! They diminish the aesthetic of any living space especially modern desktops where every other electronic is slick and refined.
Made from high-density aluminium and electroplated to space-grey. The Cool Case [+] has only 4 visible screws under its belly. It is also a unified heat-sink that is 300% more efficient than previous Conductors. It is audio jewellery at its finest and It looks and plays very cool.
Smooth Control
The all-new OLED screen and interface program deliver a calming and intuitive user experience. Its machined solid aluminum knob offers the fines control and feels luxurious.
The Sound
Through a quieter, darker background, microdynamics propels forward by the sheer energy of the Conductor 3X. It lets you dive even deeper into the miracle we called music.
When listening to Sinner’s Prayer by Ray Charles and B.B. King. Ray’s authentic vocal dramatics, frail yet still capable of true emotion and flashes of fire like a dimming star mixing with King’s stinging guitar and barking vocals Two partners in soul and titans of music, trying to top each other, ripping the joint apart and put it back together again, competitive yet completely in tune and sharing their love for music. A perfect balance of soul, love and heart displaying in full gory.
Advanced Digital
Max Power X 5
The Cool Case
Smooth Control
The Sound
- Originalemballasje
- Ja
- Orig. kvittering
- Ja
- Forsendelse
- Kan sendes
