Selger 1 stk av CEC sine fantastiske dempeplattformer.
Disse fungerer bra under alle komponenter og spesielt under CD spillere og platespillere.
Nypris er ca 12000
The CEC Wellfloat Boards works best for amplifiers,
speakers, and components. We highly recommend
them for our belt drives and turntables. They use a
patented pendulum movement floating suspension
system.
The system consist of an U-shaped special stainless steel spring connected via a piano wire.
When weight is applied on top board, U-shaped stainless steel comes down to make piano wire free movement.
Piano wire works for pendulum movement.
Thus the vibration up-down, right-left, forward-backward will be totally absorbed. This is super effective at minimizing floor vibrations and eliminating microphonics within components.
Included with the platform are 4 floating suspension systems that are indispensable to maximizing the performance of the platform. You will be thrilled with the improvements in resolution, bass, and sound-staging.
CEC ASB4560WF
Dimensions: 450 x 600 x 58(h) mm,
Weight: 9Kg.
Weight capacity: 5-90kg.
CEC ASB3545WF
Dimensions: 350 x 450 x 58(h)mmm,
Weight: 5,5Kg.
Nypris er ca 12000
system.
CEC ASB4560WF
Weight: 9Kg.
CEC ASB3545WF
Weight: 5,5Kg.
