Beskrivelse
Dali concept 2. Spiller som de skal, men det ene frontsoffet er knekt (se bildet)
Specifications
Specifications
Product Series | CONCEPT |
Speaker Type | Front Rear Surround |
Frequency Range (+/-3 dB) [Hz] | 43 – 25,000 |
Sensitivity (2,83 V/1 m) [dB] | 87.0 |
Nominal Impedance [Ω] | 8 |
Maximum SPL [dB] | 108 |
Recommended Amplifier Power [W] | 40 – 120 |
Crossover Frequency [Hz] | 3,000 Hz |
High Frequency Driver | 1 x 1″ Soft Textile Dome |
Low Frequency Driver | 1 x 6.5″ Paper Fibre Cone |
Enclosure Type | Bass Reflex |
Bass Reflex Tuning Frequency [Hz] | 42.5 |
Connection input(s) | Single Wire |
Magnetic Shielding | Semi Magnetic Shielded |
Recommended Placement | On-Wall Shelf Stand |
Dimensions With Base (H x W x D) [mm] | 390 x 200 x 260 |
Weight [kg] | 6.3 |
Accessories Included | Manual Rubber Bumpers |
Finish | Cherry Vinyl Light Oak Vinyl |
- Originalemballasje
- Nei
- Orig. kvittering
- Nei
- Forsendelse
- Avtales nærmere
