Endpoint Audio
Butikk DarTZeel CTH 8550 Mk2
Denne annonsen er utgått.
Integrert forsterker
Selges
Tilstand
Ny
Utløpsdato
Fylke/land
Vestfold
Pris
Kr 500.000
Annonse beskrivelse
Annonse nummer: 249764
DarTZeel er audioutstyr i det ypperste toppsjiktet, og er et merke jeg har hatt et godt øre til i flere år. Jeg hadde forforsterkeren NHB-18NS for noen år tilbake, og har vært fan siden.
Dette er den integrerte forsterkeren CHT 8550 Mk2 - plassvennlig High End!
CTH-8550
The CTH-8550 embodies everything that an integrated amplifier should be:
Compact, practical, versatile, musical, elegant and powerful.
Until recently, integrated amplifiers only achieved distinction despite trade-offs in design.
Most integrated amplifiers have been built under budget and pricing constraints that leave little room for high performance.
That's why darTZeel is proud to present the CTH-8550, the first integrated amplifier without compromise.
With its dual-mono architecture, 50-ohm Zeel inputs, optional high-quality phono stages and remarkable versatility, the darTZeel CTH-8550 is the integrated amplifier of choice for audio enthusiasts.
CTH-8550: at the heart of the music
With up to nine analogue inputs for RCA, XLR and Zeel 50-ohm cables, all sources including turntables are accommodated.
Boasting ample power reserve capacity, a wide range of functional features and unrivalled ease of use, the CTH-8550 is the most complete integrated amplifier in its field.
Nominal Output Power
200 watts RMS (230 watts peak) @ 8 ohms
330 watts RMS (360 watts peak) @ 4 ohms
400 watts RMS (500 watts peak) @ 2 ohms (software limited)
Line Gain
0 dB nominal, up to + 12 dB (+22 dB custom)
Power Stage Gain
26 dB @ 8 ohms
Analog Input Impedances
1 x Zeel BNC 50 ohms
1 x RCA line > 30 kohms
1 x XLR > 30 kohms
Optional Phonos:
Phono MM = 47 kohms. Neumann RIAA 4th pole included
Phono MC = 1 kohms. Neumann RIAA 4th pole included
Line Output impedances
RCA = 75 ohms, darT BNC = 50 ohms
Speaker Output Impedance
< 0.33 ohms from 20 Hz to 20 kHz (measured under 8 ohms)
Frequency Response
2 Hz - 200 kHz, +0, -3 dB
Rise Time
< 0.8 µs
Slew Rate
> 88 V/µs, peak-peak
DC Output Voltage
< ± 15 mV max
Total Harmonic Distortion (THD)
< 1 % from 7 Hz to 77 kHz within the output dynamic range
Temporal Distortion
None, at any level and load, as specified above
Crosstalk
< - 90 dB from 20Hz to 20kHz
Signal to noise ratio
> 115 dB (A) @ nominal power
Power consumption
3 watts Standby, 40 watts @ idle, 1000 watts @ maximum output power
Size in mm
440 x 350 x 170 (WxDxH). Total deep with handles : 415mm
Size in inches
17.32 x 13.78 x 6.7 (WxDxH). Total deep with handles : 16.4 inches.
Net weight
28 kg
Style and functional features
The darTZeel CTH-8550 is equipped with a plasma control panel, offering excellent contrast when viewed from any angle. A range of menus allows you to individually configure all settings for each input source.
Ease of use
Volume control is handled by an optical encoder notched magnetically, for unrivalled touch and precision. Round steel buttons add to the unit's appeal.
Originalemballasje
Ja
Orig. kvittering
Ja
Forsendelse
Avtales nærmere
Endpoint Audio
Torget karakterer
Vurderinger (40)
Andre annonser av Endpoint Audio
