Vi selger vår strøkne utstillingsmodell fra Revel.
Veldig god høyttaler fra annerkjente Revel!
Ta kontakt dersom du lurer på noe.
Veilpris: 45.900,-
Veilpris: 45.900,-
Net Weight | 58 lb (26 kg) |
Crossover Frequencies | 275 Hz, 2150 Hz |
Enclosure Type | Bass-reflex via Front-firing Port |
Finishes | Piano Black, Piano White, or High Gloss Walnut |
High-frequency Driver Components | 1” (2.5 cm) Aluminum Tweeter with Acoustic Lens Waveguide |
Nominal Impedance | 8 Ohms |
Input Connections | Binding Posts |
Low Frequency Extension | -10dB@33Hz -6dB@40Hz -3dB@52Hz |
Low-frequency Driver Components | Dual 6.5” (16.5 cm) Aluminum Cone, Cast-frame Woofers |
Mid-frequency Driver Components | 5.25” (13.3 cm) Aluminum Cone, Cast-frame Midrange |
Recommended Amplifier Power | 50-200 |
Sensitivity | 88dB |
Dimensions | 41.4" x 9.8 " x 13.6" (1052mm x 249mm x 347mm) |
- Originalemballasje
- Ja
- Orig. kvittering
- Ja
- Forsendelse
- Kan sendes
