Vi selger vår strøkne utstillingsmodell fra Revel.
Veldig god høyttaler fra annerkjente Revel, denne er det veldig mye skriverier om på nettet, og ansees å være veldig god.
Legger ved en link her: https://www.audiosciencereview.com/...ds/revel-m106-bookshelf-speaker-review.14363/
Ta kontakt dersom du lurer på noe.
Veilpris: 26.900,-
Veilpris: 26.900,-
- Transducers feature motor-system distortion-reduction mechanisms that stabilize the flux field during operation
- Ribbed aluminum cones achieve piston like behavior eliminating major sources of resonance
- New waveguides provide consistent sound over a wide listening area
- Enclosures created by Italian luxury cabinetmakers
- Fluid-model port designs keep distortion low
- Advanced crossovers optimize timbre accuracy both on axis and throughout the room
Height | 15" (38.1 cm) Note Optional Stand Adds 25" (63.5 cm) |
Width | 8.3" (21 cm) |
Depth | 11" (27.8 cm) |
Weight | 19 lb (8 kg) Note Optional Stand Adds 8 lb (4 kg) |
Crossover Frequencies | 2.3 kHz |
Enclosure Type | Bass-reflex via Rear-firing Port |
Finishes | Piano Black or High Gloss Walnut |
High-frequency Driver Components | 1” (2.5 cm) Aluminum Tweeter with Acoustic Lens Waveguide |
Nominal Impedance | 8 Ohms |
Input Connections | Binding Posts |
Low Frequency Extension | 10dB@39Hz -6dB@54Hz -3dB@59Hz |
Low-frequency Driver Components | 6.5” (16.5 cm) Aluminum Cone, Cast-frame Woofer |
Recommended Amplifier Power | 50-150 |
Sensitivity | 87 dB |
- Originalemballasje
- Ja
- Orig. kvittering
- Ja
- Forsendelse
- Kan sendes
