Denons toppmodell med frontloading, kassett legges vannrett inn
Kan brukes med Logitech fjernkontroller
Meget godt velholdt og i topp stand
Gir topp opptakskvalitet med justeringsmuligheter av bias etc.
Selges med 9 stk. kassetter i uåpnet forpakning+ en rensekassett
Da har du en flott startpakke
Description
Features of the Denon DRS-810 include a close-loop dual-capstan tape transport, non-slip reel drive, dual power supply, dolby HX pro, dolby B and C noise reduction and manual bias adjustment.
Specifications
Type: 3-head, single compact cassette deck
Track System: 4-track, 2-channel stereo
Tape Speed: 4.8 cm/s
Heads: 1 x combination record/playback, 1 x erase
Motor: 1 x capstan, 1 x reel, 1 x actuator
Tape Type: type I, Cr02, Metal
Noise Reduction: B, C, HX Pro
Frequency Response: 20Hz to 20kHz (Metal tape)
Signal to Noise Ratio: 75dB (dolby C)
Wow and Flutter: 0.038%
Input: 80mV (line)
Output: 0.62V (line)
Dimensions: 434 x 122 x 320mm
Weight: 6.6kg
Description
Specifications
Input: 80mV (line)
Weight: 6.6kg
