Hemispheres
Denon POA T10. DUAL MONO Solgt
Denne annonsen er utgått.
Effektforsterker
Selges
Tilstand
Brukt
Utløpsdato
Fylke/land
Vest-Agder
Pris
Kr 2.990
Annonse beskrivelse
Annonse nummer: 176530
En god start på rå lyd. Denon Dual Mono POA T10 Reference S, THX power amp Selges pga overgang til monoblokker.
THX Ultra Certified 2-channel Power Amplifier POA-T10 The POA-T10 dual monaural power amplifier provides superb stereo reproduction, and is an ideal choice for adding additional amplifier channels to a multi-channel system. For example, when combined with Denon's AVC-A10SE THX Surround EX A/V amplifier, the POA-T10 can be used as the stereo front channels (left and right) amplifier, or the surround center back channels amplifier. The POA-T10 meets Lucasfilm's stringent THX Ultra certification requirements, and provides 190 watts (6 ohms, EIAJ) of power per channel. n THX Ultra Certified Lucasfilm's stringent THX Ultra certification for power amplifiers includes dozens of tests and specification requirements, all to ensure accurate reproduction of motion picture soundtracks and musical performances. All aspects of power amplifier performance are thoroughly verified, to ensure inaudible noise, wide dynamic range, extended frequency response with accurate spectral response, and the ability to drive any modern loudspeaker regardless of impedance or efficiency. n Dual Monaural Configuration Unlike conventional stereo power amplifiers, which rely upon a shared power supply for both amp channels, the POA-T10 features Denon's perfect Dual Monaural Configuration, with a separate high current power transformer and DC storage supply section for each amplifier channel. This provides the widest dynamic range, along with tremendous reserve capacity, compared to conventional stereo amplifiers. n Stabilized DC Characteristics The use of a FET for differential input of one package type with superior direct current (DC) temperature characteristics and the ability to fine-adjust each channel individually have realized a high precision of 1 mV or less (standard value) in the output DC voltage of the POA-T10. This high-precision voltage is approximately one tenth that of conventional models and is the main reason these models are able to reproduce low-level signals with such exceptional fidelity. n Wide-Range Play Capability For Next-Generation Audio Formats such as DVD-Audio and SACD n A-B Speaker switching For both channel n Strictly Selected Parts For High Sound Quality A large number of high-performance parts, such as the electrolytic capacitor customized for high sound quality, OFC wiring material, film capacitor and resistors, have all been subject to stringent listening tests during their selection process to ensure unfettered, high-grade sound reproduction. n Remote Power ON/OFF Rear panel mounted remote power on/off terminals are provided, for connection to Denon components such as the AVC-A10SE, for one-button power turn-on and turn-off convenience. This allows the power amplifier to be mounted in an out-ofthe- way location, thereby saving valuable shelf space for more importantly accessible source components, for example. n Specifications Rated output . . . . . . . . . . . . 190 W x 2 (6 ohms, EIAJ) 160 W x 2 (8 ohms, EIAJ) 120 W x 2 (8 ohms, 20 Hz - 20 kHz, THD 0.02 %) 200 W x 2 (4 ohms, 1 kHz, THD 0.5%) Total harmonic Distortion . . . 0.008 % (-3 dB at rated output, 8 ohms, 20 Hz - 20 kHz) Inter modulation Distortion . . 0.002 % (60 Hz/7 kHz : 4/1 at rated output, 8 ohms) Frequency response . . . . . . 1 Hz - 100 kHz +0, -3 dB (at 1 W) Input sensitivity . . . . . . . . . . 1.1 V Input impedance . . . . . . . . . 47 kohms Output impedance . . . . . . . . 0.1 ohms (1 kHz) Signal-to-noise ratio . . . . . . . 110 dB (IHF, A-weighting) Speaker . . . . . . . . . . . . . . . . A or B 4 ohms - 16 ohms A + B 8 ohms - 16 ohms Power supply . . . . . . . . . . . AC 230 V, 50 Hz Power consumption . . . . . . . 330 W Dimensions . . . . . . . . . . . . . 434 (W) x 135 (H) x 353 (D) mm Weight . . . . . . . . . . . . . . . . 12.3 kg
Kan byttes i Tandberg TR 2080 i estetisk perfekt stand, integrert amp eller platespiller. +-
Frakt 250. vipps.
Hemispheres
Rush fan (og litt Tool)
Torget karakterer
Vurderinger (183)
Andre annonser av Hemispheres
  • 4 x Marillion
    Selges av: Hemispheres
    Kr 350
  • 12V AC AC power
    Kr 250
