Hemispheres
Dynaudio Audience 5 Solgt
Denne annonsen er utgått.
Stativhøyttalere
Selges
Tilstand
Brukt
Utløpsdato
Fylke/land
Rogaland
Pris
Kr 2.200
Kjøpt av
Cobra2
Annonse beskrivelse
Annonse nummer: 52646
Selger et sett Dynaudio Audience 5 da jeg har for mange høyttalere, eller evt. bytte i annet hi-fi utstyr.
God stand og hele og fine deksler.
Spelar rent och snyggt med massor av detaljer. Härligt musikaliska. Aldrig tröttsamma. Man kan lyssna i timmar.
(Taken from the original brochure)
Most crimes these days are not committed on the screen. But right next to it. Sky scraper explosions die soft, not hard, from paper cones. Voice coils measuring 0,75" make Frank McClane sling a teeny lady gun. The Cannonball racers don´t even get past the crossover. Instead of Hollywood, you get, say, Cleveland. And the culprit? Right. The drivers in most surround speakers are bought in from any old Dirty Harry. And they sound that way.
But fear not ? the legendary Danish engineers from Dynaudio are coming to the the rescue with the Audience series for uncompromised home theater surround sound. The most compact solution is the Audience 5: its unique soft dome tweeter has an aluminium voice coil which is literally lighter than a feather.
Guaranteeing unlimited dynamics, without peaks and valleys in the frequencey response, and true high end precision. In the bass, and despite its compact dimensions, the Audience 5 takes no prisoners: Dynaudio´s original 3" magnum voice coil is three times larger than your average voice coil. Which means greater control and improved power handling. Not forgetting a pahse-optimized membrane geometry, tightly defined inner damping and fully ventilated center magnet system. The only element we saved a bit on is the body. It is built not by hand, but by a Danish machine. On the other hand, in the Audience 5, criminally good drivers and a well camouflaged enclosure add up to an offer one can´t refuse.
Max Effekt 150Watt. Impedans 4 ohm.
Frekv. 50-20000Hz, Vikt 5,5kg
B,H,D 205x310x240mm. Färg Bruna
Kan sendes. Frakt tilkommer.
Hemispheres
Rush fan (og litt Tool)
Torget karakterer
Vurderinger (183)
Andre annonser av Hemispheres
  • Emit 50 sort, kjøpes
    Ønskes kjøpt av: Hemispheres
    Kr 15.000
