Moet Audio
Butikk Elipson HERITAGE XLS 15 i demo
Gulvhøyttalere
Selges
Tilstand
Ny
Utløpsdato
Fylke/land
Rogaland
Pris
Kr 27.990
Annonse beskrivelse
Annonse nummer: 249392
Klassiskt retro design med 12" bass av franske Epsilon. Kraftig og dyp bass.
Tester:
https://www.avforums.com/reviews/elipson-heritage-xls-15-speaker-review.18592/
https://blog.son-video.com/en/2020/12/elipson-heritage-xls-15-a-perfectly-revamped-vintage-speaker/
The Elipson Heritage XLS 15 speaker embodies vintage elegance combined with cutting-edge technology. Designed as a three-way bass-reflex system, it features an imposing 12 inch woofer for powerful and deep bass.
The Elipson Heritage XLS15 speaker stands out for its modular vintage design, offering real flexibility thanks to its two supplied bases. But beyond its shape, it is its musicality that is the most appealing.
This 3-way model of compact dimensions and tuned front bass-reflex load benefits from a new 12'' diameter cellulose woofer with a powerful magnetic system, a new 2.2'' diameter treated dome midrange covering nearly three octaves and finally a 0.87'' diameter silk dome tweeter derived from the famous tweeter equipping our flagship model of the Prestige Facet series.
A fine amplitude adjustment of 2dB allows to adjust the midrange and treble registers according to the listening room or to one's hearing affinity. In addition, a 7° tilted base (included) is available for perfect acoustic phasing, or an optional metal stand raises the speaker by 19 cm in addition to the tilt.
Energy and control of the bass, definition and relief of the midrange, delicacy and extension of the high register characterise the sonic pleasure of this Elipson Heritage XLS15 speaker.
TECHNICAL DATA
Type : 3-way compact speaker
Tweeter : 22 mm silk dome
Medium : 55 mm treated dome
Bass : 300 mm cellulose pulp Bass reflex Frontal
Frequency range : 40 Hz - 25 kHz +/- 3 dB
Crossover frequencies : 700 & 5000 Hz
Sensitivity : 92 dB / 1m / 1w
Impedance : 6 Ohms
Recommended Amplification : 50-200 W
Power (RMS) : 200 W
DIMENSIONS
Dimensions W x H x D : 420 x 730/700 x 339 mm
Weight : 28 kg
PACKAGING
Inner box dimensions W x H x D : 845 x 535 x 455 mm
Outer carton dimensions W x H x D : 875 x 555 x 475 mm
Packed per piece
Gross weight : 34.5 kg
GOOD TO KNOW
Designed and developed in France
Originalemballasje
Ja
Orig. kvittering
Ja
Forsendelse
Kan sendes
Moet Audio
Torget karakterer
Vurderinger
Andre annonser av Moet Audio
