Endpoint Audio
Butikk EMT 912-HI - DIN Connector - Demomodell
Platespiller tilbehør
Selges
Tilstand
Brukt
Utløpsdato
Fylke/land
Vestfold
Pris
Kr 55.300
Annonse beskrivelse
Annonse nummer: 251826
EMT 912-HI
Product Flyer | Datasheet | Manual
Within the new EMT tonearm technology, we were able to combine most modern bearing- and manufacturing-technology with the traditional EMT design. Thus, the sound properties are im-proved significantly, while at the same time the long history of this product-line is respected.
- High-end 12-inch tonearm with headshell for 1/2” hi-fi cartridge connection
- Precision bearing technology, advanced tension compensating mechanism
- Fine-pitch thread ring for VTA adjustment
- Contactless magnetic skating compensation device
- Counterweight with integrated scale for VTF
- Rigid headshell with azimuth correction mechanism
Effective mass:11.4g
Cartridge weight:8…25g
Effective length:310.15mm
Offset angle:17.55°
Overhang:13.15mm
Null points:120.9 / 66.04mm
Output (Standard):wire outlet 20cm
Output (Option DIN):5-pin DIN outlet
www.stereophile.com/content/emt-128-phono-preamplifier
Originalemballasje
Ja
Orig. kvittering
Ja
Forsendelse
Kan sendes
Endpoint Audio
Torget karakterer
Vurderinger (38)
Andre annonser av Endpoint Audio
