EMT 912-HI
Product Flyer | Datasheet | Manual
Within the new EMT tonearm technology, we were able to combine most modern bearing- and manufacturing-technology with the traditional EMT design. Thus, the sound properties are im-proved significantly, while at the same time the long history of this product-line is respected.
- High-end 12-inch tonearm with headshell for 1/2” hi-fi cartridge connection
- Precision bearing technology, advanced tension compensating mechanism
- Fine-pitch thread ring for VTA adjustment
- Contactless magnetic skating compensation device
- Counterweight with integrated scale for VTF
- Rigid headshell with azimuth correction mechanism
Effective mass: | 11.4g |
Cartridge weight: | 8…25g |
Effective length: | 310.15mm |
Offset angle: | 17.55° |
Overhang: | 13.15mm |
Null points: | 120.9 / 66.04mm |
Output (Standard): | wire outlet 20cm |
Output (Option DIN): | 5-pin DIN outlet |
- Originalemballasje
- Ja
- Orig. kvittering
- Ja
- Forsendelse
- Kan sendes
