Jeg har både 1.05mV og 0.3mV på lager.
Alle EMT Pickuper - inkludert Tondose pickupene, kommer med kostnadsfritt valg 1.05mv/300 ohm, 0.6mV/150 ohm, og 0.3mV/100 ohm.
EMT ble grunnlagt allerede i 1940, men startet først å produsere pickuper i 1960. I dag består sortimentet av 8 pickuper - alle håndlaget i Turbenthal i nærheten av Zurich.
EMT HSD 006 er EMT's rimeligste stereopickup som kommer i en Rød Alu body.
Stereophile ranker denne som B blant sine anbefalte produkter 2020!
Her er hva de skriver:
EMT HSD 006: $1595
Subsequent to moving their phono-cartridge division from Germany to Switzerland, EMT introduced the new entry-level HSD 006, built into a semi-open aircraft-aluminum body with threaded mounting holes. Inside is a version of EMT's classic TSD-series motor, characterized by high impedance (24 ohms) and output (1.05mV), with an alnico magnet and an aluminum cantilever to which is fitted a Super Fine Line stylus. Recommended downforce is 2.4gm. In AD's system, the HSD 006 sounded "like a TSD 15, but a little more modern. All of the old model's strengths are here, but with an increase in detail." The HSD 006 impressed AD as "more spatially accomplished, and perhaps a little more tactile" than the TSD 15, and suggested that, when partnered with the right tonearm and phono stage, "it will sing." (Vol.42 No.12 WWW)
Ord fra produsenten:
The HSD 006 features our traditional stereo moving-coil generator, which has proven itself over decades in broadcast studios all over the world. The new body design makes it possible to bring professional EMT technology to your personal hi-fi system, letting you enjoy the intoxicating musicality of this outstanding transducer.
Tekniske data:
Diamond: SFL
Cantilever: Aluminium
Transducer: MC Stereo
Magnet: AlNiCo, nickel-plated
Body: Aluminium, red anodized
Connection: 1/2" ? 4pin
Vertical Tracking Angle: 23°
Weight: 12g
Tracking force: 2,4g
Output voltage: 1.05mV @ 5cm/s
Compliance: 12µm/mN
Frequency response: 20 - 25?000Hz
Impedance: 2x 24?
Recommended load: 200 - 300?
_______________________________________________________________________
De andre EMT pickupene er:
HMD 025 - MONO
JSD 6
JSD 5
JSD Pure Black
JSD Pure Lime
JSD VM - Med variabel masse!
JSD Platinum
Prisene starter på 15.500,- og går opp til 60.000,-
Tom Egil
47 83 29 22
tom@endpointaudio.no
EMT HSD 006: $1595
Tekniske data:
Diamond: SFL
Weight: 12g
Compliance: 12µm/mN
Impedance: 2x 24?
HMD 025 - MONO
JSD 6
JSD 5
JSD Pure Black
JSD Pure Lime
JSD Platinum
Tom Egil
47 83 29 22
- Originalemballasje
- Ja
- Orig. kvittering
- Ja
- Forsendelse
- Kan sendes
