Moiz Audio
Butikk Ferrum Audio Hypsos 5-30V 6A hybrid Strømforsyning Solgt
Løse komponenter
Selges
Tilstand
Brukt
Utløpsdato
Fylke/land
Pris
Kr 8.995
Annonse beskrivelse
Annonse nummer: 231651
Brukt enhet
overhalet av ferrum.Alt ok!
2.1mm dc kabel følger med.
Justerbare hybrid( lineær/switch) strømforsyning som er softwarestyrt. Leverer nok strøm til å drive kraftige hodetelefonforsterkere( Burson), DACer,musikkstreamere, RIAA trinn etc
produktinfo:
  • Power input:
    100-240Vac/50-60Hz (EU/US Version)
    90 – 110Vac/50-60Hz (JP Version)
    IEC C14 power inlet, a fuse holder with power on/off switch plus two-stage EMI filter for low impedance load with better noise attenuation in low frequency applications
  • Mains cable: US/EU/UK
  • DC OUT cable:5×2.5mm DC plug / 5×2.1mm DC plug
    Custom cables made to order at additional cost
  • Output Voltage Range: 5-30 [V]
  • Max Continuous Output Current (for V_out below 10V): 6 [A]
  • Max Continuous Output Current (for V_out higher than 10V): l_out= 60[W] / DCout[V]
  • Max Continuous Output Power (for V_out below 10V): P_out = V_out[V] * 6[A]
  • Max Continuous Output Power (for V_out higher than 10V): 60W
  • Dimensions (without knob, feet and connectors) (W x D x H , mm / inches): 217.5 x 206.5 x 50.0 / 8.6 x 8.1 x 2.0
  • Net weight (kg / lb): ~ 2,8 / ~ 6.2
  • Primary winding fuse: IEC 5x20mm fuse, 3.15AT, 250V
  • Secondary winding fuse: Littelfuse 154004T, 4A
Originalemballasje
Ja
Orig. kvittering
Ja
Forsendelse
Kan sendes
Moiz Audio
Torget karakterer
Vurderinger (122)
Andre annonser av Moiz Audio
