Nypris for alt er ca: (ink. frakt, mva og slikt.)
Chassis 5000NOK
Deluxe 5U Aluminum
The Deluxe Chassis is the ultimate DIY Amplifier playground. We don't know of another chassis for sale in the world that makes life as easy for DIY Audio enthusiasts. Packed with features so you can focus on having a good time building your amp instead of getting roadblocked by the hardest...
diyaudiostore.com
Trafoer: 1650/stk = 3300NOK
AA-98048 Ring Core Transformer 600 VA 2x 24 VAC Noratel
Next-day delivery! Buy Ring Core Transformer 600 VA 2x 24 VAC in the Distrelec Online Shop | We love electronics
www.elfadistrelec.no
Print F5t 600NOK
F-5T
This set of circuit boards is used to make the F-5 Turbo power amplifier from the mind of DIY hero and audio genius, Nelson Pass. One set of PCBs will make a stereo F-5T v2, or a single monoblock F-5T v3. This is the third revision of the boards, which has nothing to do with using them to make...
diyaudiostore.com
Print PSU: 600NOK
Universal Power Supply
The all new Universal PSU V3.0. Bigger and badder than ever, complete with a well illustrated build guide. Fully compatible and optimized for the new Deluxe 4U and Deluxe 5U chassis to allow easy installation on the base, chassis front panel, or on riser panels Can accomodate 35mm, 30mm and 25mm...
diyaudiostore.com
Mosfets/transistorer ca: 1100NOK
F-5T V1/2 Transistor Kit
Included in this kit are the semiconductors needed to complete an F-5T V1 or V2 amplifier, with the exception of the input JFETs, which can be sourced separately through the store. MOSFETs matched in accordance with F5T V1 operating conditions. This is enough transistors for 2 channels (one...
diyaudiostore.com
Kondiser til PSU: ca 1000NOK
Softstart print: ca 600
Soft Start & Speaker Turn-On Delay / DC Protector Combo
This pack includes one Soft Start Board and one Speaker Turn-On Delay and DC protector board. They are not available for purchase separately. Soft Start Board Every time you switch on your monster (or not so monster) power amplifier, the initial current drawn from the mains can be many times...
diyaudiostore.com
+ annet som el lytter, motstander, jfets til inngang, små "heatsinks", releer, chassis kontakter etc.
Så blir faktisk når man regner på det over 12000 i deler.
Jeg kan la det gå for 6000 komplett?
Dette er kvalitet og alt er via renommerte shopper som elfa, mouser, rs online, diyaudio store etc..
Prosjektet blir nok ikke realisert for min del tenker jeg. Har for mange planer og altfor lite tid...
Vis vedlegget 638132
Solide dimensjoner. 5u chassis
Vis vedlegget 638133
Frontplate børstet aluminium. 1cm tykk
Vis vedlegget 638134
Psu med 15000uf kondiser helt nye ubrukte. CRC psu
Vis vedlegget 638135
Noratel 600va trafoer
Vis vedlegget 638136
Vis vedlegget 638137
Softstart x2
Vis vedlegget 638138
Print og nye matchende mosfeter. Ville gjøre alt på nytt
Vis vedlegget 638139
Odd Magnus
- Originalemballasje
- Nei
- Orig. kvittering
- Nei
- Forsendelse
- Avtales nærmere
