Ord pris 137,000kr
Fantastiske høyttalere som er i det absolutte topp sjiktet. Her får du hele frekvensområdet levert med den største selvfølgelighet. Uansett volum så leverer de lyden like krystallklart og uanstrengt.
Frequency response (+/- 3 dB) 36 - 27.000 Hz
Impedance 4 ohms
Sensitivity 90 dB (1 W / 1 m)
Max. acoustic pressure 112 dB
Frequency dividing network 1st and 2nd order phase and impedance corrected filter
Function principle bass reflex
Bass and midrange system two 180 mm FISCHER & FISCHER cone speakers with carbonized paper, carbon foil sandwich membrane and aluminium phaseplug
Treble system one FISCHER & FISCHER-Air Motion Transformer (AMT), special custom made by Mundorf
Connecting terminal Bi-wiring, with pure silver bridges, 63 A connecting terminals, rhodium plated
Cabinet material 20 / 23 mm thick low-resonance natural slate
Floor system aluminium, levellable
Dimensions slate cabinet (H x W x D) 1096 x 220 x 300 mm
All over dimensions, incl. floor system 1141 x 305 x 350 mm
Weight 69 kg.
Impedance 4 ohms
Weight 69 kg.
- Originalemballasje
- Ja
- Orig. kvittering
- Ja
- Forsendelse
- Kan sendes
