Kjøpt 7. Oktober 2023 direkte fra Hagerman Audio Labs.
Kun testet og har deretter ligget i esken da jeg gikk for en Audiodharma Cable Cooker som passet mitt bruk bedre, så denne er ny.
Original kvittering, manual og tilbehør medfølger.
Nypris etter fortolling og fortollingsgebyr er 4 110,-
(annonsen ligger også på Finn.no om du f.eks. foretrekker Fiks Ferdig tjenesten de tilbyr)
- For info, fyldige testimonials og reviews, følg linken under -
https://hagerman-audio-labs.myshopi...s/products/frybaby3-compact-burn-in-generator
The FryBaby3 audio system conditioner is a burn-in signal generator designed especially for cables and interconnects. It can also be used to burn-in linestages, phonostages, and amplifiers. The sophisticated electronic waveform, a combination of wideband noise and variable frequency amplitude modulation, is designed to exercise both low and high frequency characteristics of conductors and insulators.
Testimonials
Testimonials
- "Your process of treating the cables takes the sound to another dimension a higher level of audio quality, almost like another world. Much clearer and detailed with more depth and realism and with much less straining and fatigue. A good classical recording sounds pretty similar to when I see the LA Philharmonic in person sitting close in the front rows. I am very happy to put it mildly."
- "Hi Jim, just wanted to give you a some feedback. I am just now listening to a cable that’s been burnt in with your frybaby. I hear a pretty big improvement in the sound. From a cable to one 4 times the cost it is quite an improvement. So much so that I’m going to upgrade all my other applicable cables to higher quality ones. I wonder how many people are unaware that audio devices need to be broken in. I’ve read that a lot of people claim it is a joke and not real. It is definitely a fact. I am a serious classical pianist and keyboardist so I have hearing that is probably more sensitive than most people. Thanks a lot for all your efforts in putting this device together and making it available to the public. I am retired so I have a lot of extra time to listen to music and with your help I will enjoy it much more."
- "Your frybaby is the best $250 I ever spent on any audio component. Bless you."
- "So far I’ve had great results with my Nordost speaker cables and Audioquest power cords. The difference in sound is not subtle and it is much more musical and enjoyable overall."
- "So far I have been using it to burn in my Belden 8402 interconnects and I must say it has been revelatory. They have been in my system for well over a year and I use the system for quite a few hours every day (I work at home) so should be well burned in in the conventional sense, however four days for each interconnect on the Frybaby2 has changed them to the extent you would think they were different, much more expensive, interconnects. Each interconnect has received roughly 24 hours voltage burn in and then roughly 72 hours current burn in, whether this is optimal I have absolutely no idea but it seems to have worked. The main changes are in the bass which is much better defined and richer. This in turn has given a better sense of soundstage, etc."
- Orig. kvittering
- Ja
- Forsendelse
- Kan sendes
