Gjallarhorn Audio
Butikk Furutech Daytona 303E (innbyttevare)
Strømfiltere
Selges
Tilstand
Brukt
Utløpsdato
Fylke/land
Akershus
Pris
Kr 12.500
Annonse beskrivelse
Annonse nummer: 244855
Vi tok nylig inn en Furutech Daytona 303E strømrenser i innbytte.
Listepris fra den gangen produktet var nytt ser ut til å være rundt kroner 30 000,-
Bruktpris: NOK 12 500,- (NB! Original emballasje mangler, men brukermanual og LED-lampe er ivaretatt.)
Frakt: Kan hentes på vår adresse eller sendes med Posten (uoriginal emballasje vil måtte benyttes)
The Daytona 303 Multi-Mode AC Filter/Power Distributor
Featuring Resonance-Damped Receptacles and Locking Plates
EMI-Absorbing Formula GC-303
•4 unfiltered outlets (FT-D15A (R) X 2)
•Power amplifiers (Direct 1 / Zone 3)
•Preamplifiers, analog devices (Direct 2 / Zone 2)
•6 Digital filtered outlets (FP-15A-N1(R) X 3)---Transparent Cover (Zone 1)
•DVD and DVR (Filter 1)
•CD, Cable and SAT(Filter 2)
•TV and Projector (Filter 3)
•All Furutech Pure Transmission Receptacles feature nonmagnetic rhodium-plated α (Alpha) phosphor bronze fittings
•Beautifully-crafted highest-grade aluminum panels and painted steel chassis
•Effectively shields against RFI (Radio Frequency Interference)
•Layer of EMI-absorbing Formula GC-303 bonded to bottom plate
•Effectively shields against EMI (Electro Magnetic Interference)
•Internal wiring: Furutech Alpha-10, 5.5 sq. mm (10 AWG) for low electrical resistance
•Conductors insulated with resonance-absorbing tubing
•Front panel • 8 indicators for abnormal operation
•Abnormal voltage indicator • Red
•Zone 1, 2, 3 • Green
•Correct path indicator for wiring • Green
•Breaker indicator • Red
•Digital voltage meter • Red
•Digital amperage meter • Red
•Rear panel
•Attachable LED lamp for easy viewing
•Three sets of surge-protected coaxial terminals
•Surge-protected 3-way phone connections 2.5GHz coaxial connections
•Input x 1 • Output x 2
•3 Remote control triggers
•AC 230V In / DC 3~30V In / DC 12V Out (attachment)
•Standard rack mounting plates
•Sequence switch
•Display Dimmer switch for Display panel Light or Normal
•All conductors treated with Furutech’s α (Alpha) Cryogenic and Demagnetizing Process
Originalemballasje
Nei
Orig. kvittering
Ja
Forsendelse
Kan sendes
Gjallarhorn Audio
Torget karakterer
Vurderinger (100)
Andre annonser av Gjallarhorn Audio
