Dalemark
Gold Note DS1000 MKII
Denne annonsen er utgått.
D/a konverter
Selges
Tilstand
Brukt
Utløpsdato
Fylke/land
Vest-Agder
Pris
Kr 26.000
Annonse beskrivelse
Annonse nummer: 242116
Gold Note DS1000 mkII Streamer/DAC for salg. Unik sjanse for og sikre seg en utrolig vellydende Streamer/Dac. Dette er noe av det ypperste innen dac, med PCM1792A. Denne er handlet av PM Audio høsten 2019.
Specifications
Dimensions: 430mm L | 135mm H | 375mm D
Weight: 15kg
Main features: DSD Streamer with integrated DSD D/A Converter
Frequency response: 5Hz-200kHz +/-0.3dB
THD – Total Harmonic Distortion: 0.001% max
Signal to noise ratio: -125dB
Dynamic response: 129dB
Output impedance: 50ohm
Phase response: linear phase, absolute phase inverted
Digital filter: proprietary Zero-Clock circuit enabling three different Master Clock
Volume control: switchable On/Off Digital partializer
Audio outputs: stereo RCA @ 2Volt and balanced XLR @ 4Volt
Line output level (fixed): 2V RMS RCA and 4V RMS XLR
Digital output: S/PDIF, 75ohm RCA 24bit
Audio inputs:
Digital input: one RCA S/PDIF coaxial and one TOS-optical asynchronous 24/192
USB: asynchronous DSD 64/128 and PCM up to 24/192 High Speed 2.0 port
USB: two USB-A front ports to feed USB flash memories, HDD FAT & NTFS
Analogue input (optional): Stereo balanced XLR
Connectivity:
LAN/WLAN WiFi: 802.11b/g via RJ45 10/100Mbps socket and Antenna
Infrared remote: RC5 proprietary code
Supported audio formats:
AIFF (.aif, .aiff, .aifc)
WAV (.wav) packed/unpacked
FLAC
WmA Windows media Audio 9
WAX Windows media audio metafiles
ASX Advanced Stream Redirector (.asx)
MPEG-4 Advanced Audio coding File, .aac, .m4a including Apple lossless, MP3
Supported media servers: All uPnP certified media servers
Power Mains supply: 100V to 245V, 50/60Hz, depending on market destination (not convertible)
Dual-Mono power supply
Power consumption: 30W
https://www.goldnote.it/
https://6moons.com/audioreviews2/goldnote/1.html
Originalemballasje
Ja
Orig. kvittering
Ja
Forsendelse
Kan sendes
Dalemark
Torget karakterer
Vurderinger (3)
Andre annonser av Dalemark
  • SMPS400A180
    Ønskes kjøpt av: Dalemark
    Kr 123
