TT.
Grado Reference Master Solgt
Denne annonsen er utgått.
Pickuper
Selges
Tilstand
Brukt
Utløpsdato
Fylke/land
Pris
Kr 2.200
Kjøpt av
soundscape
Annonse beskrivelse
Annonse nummer: 190487
Meget lite brukt Grado Reference Master selges kun kr 2200,- + evt. frakt (Tilsvarende selges på Oslo HiFi Center for kr10990,-)
Jeg vet lite om denne, da den satt på en platespiller jeg kjøpte tidligere. Etter sjekk med mikroskop, kan jeg ikke se slitasje på diamanten. Nålefanen er dønn rett. Har stått i et røykfritt hjem. Har desverre ikke original emballasje, men pakker meget godt!
Sendes ikke i oppkrav, men Vipps er fint
Tech spec:
Frequency Response: 10-60
Principal: MI
Channel Separation at 1KHz: 40
Input Load: 47K
Output at 1KHz 5CM/sec.: 5.0mV
Recommended Tracking Force: 1.5
Stylus Type: E
Inductance: 2mH
Resistance: 2
Compliance CUs: 20
Stylus Replacement F=Factory: F
Mounting: S
Weight: 6.5
The Reference Series of wooden cartridges are a fixed coil design, hand-crafted at Grado labs from a specially selected species of mahogany. An intricate procedure of curing is done between production steps to achieve optimal sonic quality. This series generator/stylus module is not replaceable* allowing a redesigned one-piece magnetic circuit and a reduction of chassis resonances. The Reference Series utilizes manufacturing and assembly techniques of fantastic accuracy and precision, and the result is virtual perfection. Should be used only with the finest equipment. Recommended tracking force 3/4 to 2 grams.
"The Reference's reproduction of the leading edge of low-frequency information, and it's overall portrayal of bass dynamics and pitch, were the best I've heard from any cartridge: solid powerful, authoritative.?
- Stereophile, Michael Fremer
TT.
The smooth jazz guy! 😉🇳🇴
Torget karakterer
Vurderinger (99)
