Selger en av de beste oppgraderinger du kan gjøre til din Rega platespiller
Pris 2450,- inkludert frakt
Kjøpt 22.9-18 Kvittering medfølger
Nypris 3490,-
Selges pga. oppgradering til ny spiller
Groovetracer® subplatters are compatible with these turntable models: 2016 Planar 1, and 2, and 3,
Rega Planar 2, 3, 25 & Rega P1, P2, P3, Rega P3-24, P5, Rega RP1, RP3, RP40, and RP6 (See note below for RP6).
NAD 533, Goldring, and Moth Alamo
Det er bare å google så finner du mange-bare gode tilbakemeldinger på denne
NOTE: These three subplatter models also fit the RP6 but must be used in combination with either the delrin or acrylic platter.
-Important Features-
1) Ultra low coefficient of friction between the bearing surfaces minimizes vibration for a lower noise floor. The jewel bearing design is the smoothest running and longest lasting bearing available.
2) The non-magnetic record spindle is completely decoupled from the bearing axle to eliminate vibration transfer to the playing surface. This unique feature is only offered by Groovetracer®.
3) 3 point interface between the Subplatter & Platter ensures positive contact and also minimizes vibration transfer.
4) 0.0005 ?or better concentricity between the axle and hub offers vast improvement in pitch control.
5) Extended length (non-magnetic) stainless steel record spindle permits the use of clamps.
http://www.groovetracer.com/subplatter_groovetracer.htm
https://positive-feedback.com/Issue45/groovetracer.htm
Nypris 3490,-
