Dette er en strømrenser som ikke begrenser dynamikken og er for high power/current.
Produktet er strøkent. Kjøpt nytt hos Oslo HiFi Center. Kun en eier.
Nypris er 47.730,- i tillegg følger det med en Isotek Gii Titan Multilink som gir 6 uttak i tillegg til de to som er på Titan EVO3. (Gir totalt 8 strømuttak.) Denne koster ca. 10.000,- ny.
Så nypris for settet er ca: 57.730,- https://www.hifix.co.uk/isotek-gii-titan-multi-link-6-way-extension-black
Teksten nedenfor er hentet fra Oslo HiFi Center: https://oslohificenter.no/stereo/stromrens/isotek-evo3-titan
The new EVO3 Titan is a progression of IsoTek’s original multi-award winning design. Whilst utilising the unique Direct-Coupled© technology, the circuit has been radically updated. EVO3 Titan offers the ultimate high current/ power conditioner in the smallest form factor.
» Mer om produktet
PRODUCT
The ultimate high-current power conditioner in a strikingly compact form.
Designed to deliver clean power for power-hungry amplifiers, mono-blocks, active loudspeakers and subwoofers, IsoTek’s original GII Titan was built to provide optimum high current filtering in a compact design.
Det finnes flere tester på nettet. For eksempel:
https://www.isoteksystems.com/downloads/reviews/HFW_EVO3_Titan.pdf
» Mer om produktet
- Removes both Common Mode and Differential Mode mains noise.
- RFI reduction 82dB (50 ohms standard), down to 5Hz frequency range.
- Unique nine-stage conditioning network in a series parallel configuration, that delivers extremely low-impedance and high-current power. An increase of 20% Differential Mode and 600% Common Mode filtering compared to the original GII Titan. 50% of the 40A Super Titan circuit reconfigured to 20A. Delivering 4,600W continuous power with 25,000W transient ability (supply permitting).
- Two independent outlets with additional Neutrik Auxiliary. No outlets are connected together, stopping Differential Mode mains noise cross-contamination.
- Internal wiring; solid core silver plated PCOCC with FEP virtually an air dielectric.
- KERP© (Kirchoff’s Equal Resistance Path) ensures equal resistance and equal power delivery across all outlets.
- 112,500A of instantaneous protection, featuring IsoTek’s unique sequential protection system with earth fault protector.
- Available with UK, EU, US, Australian, Swiss and South African outlets.
PRODUCT
- Orig. kvittering
- Ja
- Forsendelse
- Avtales nærmere
