En av de første med Dolby Surround. Fra ca 1988
Mangler fjernkontroll. Virket 100% sist den ble prøvd (ca 1 år siden)
Specs:
Tuning range: FM, MW
Power output: 120 watts per channel into 8Ω (stereo)
Surround output: 110W (front), 15W (rear)
Frequency response: 5Hz to 50kHz
Total harmonic distortion: 0.007%
Damping factor: 45
Input sensitivity: 0.25mV (MC), 2.5mV (MM), 230mV (line)
Signal to noise ratio: 80dB (MM), 100dB (line)
Output: 230mV (line)
Video Connections: composite
Dimensions: 475 x 156 x 383mm
Weight: 13.5kg
Specs:
Damping factor: 45
Weight: 13.5kg
- Originalemballasje
- Nei
- Orig. kvittering
- Nei
- Forsendelse
- Avtales nærmere
