pelsjeger
Karan ka-s 180mkII - ny over 60k Solgt
Denne annonsen er utgått.
Effektforsterker
Selges
Tilstand
Brukt
Utløpsdato
Fylke/land
Troms
Pris
Kr 18.000
Kjøpt av
skallet hare
Annonse beskrivelse
Annonse nummer: 139935
Selger min flotte Karan forsterker grunnet ønske om å prøve noe annet. Dette er ren effektdel av den integrerte varianten som fikk mye skryt i fidelity. http://www.audiofidelity.no/uploads/2/4/0/6/24060675/59_hele.pdf
Nypris 60k++
kan sendes i original trekasse, da den akkurat går innenfor postens maksimalvekt.
Den har vært i mitt eie i snart fire år, og er således det lengstlevende komponentet i anlegget mitt for tiden. Forsterkeren er produsert i 2011, så er bare 5 år gammel.
http://www.karanacoustics.com/product/ka-s-180-mk2
This Stereo Power Amplifier hes been developed from the extremely successful integrated amplifier KA I 180. Several new solutions and use of somewhat higher quality parts gave new and higher quality to this outstanding stereo amplifier. It should be connected to KA L Mk3 or even better KA L Reference Mk3 for highest sound performance and you will be pleasantly surprised with outstanding possibilities of this amplifier.
We also recognize the fact that not everybody needs, or can afford, the most powerful of amplifiers we make. New design rated at 180 watts/channel into 8 ohms, or 300 watts/channel into 4 ohms offering superb control, authority, finesse pure natural sound.
For better sound we would suggest our other pre/power combinations.Technical data:
* A completely balanced topology with no overall feedback
* Channel separated power supplies from a custom-molded 720 VA toroidal power transformer, 80.000µF filter bank and four stages of stabilization;
* Frequency response DC-300kHz +0, -3dB
* S/N ratio better than -112 dB;
* Intermodulation distortion less than 0.03% at rated power into 8 Ohms;
* Damping factor better than 1,800:1 into 8 Ohms, 20Hz?20kHz;
* Input sensitivities: RCA-line= 750mV/30k, XLR-line= 1,5V/30k
* Pink noise RMS power 180/300W into 8/4 Ohms;
* Dimensions 500x110x380 mm (19.5?x4.3?x14.97?) WxHxD
* Dimensions in box 640x250x470 mm WxHxD
* Net weight 20 kg
* Btto weight 28 kg
Se bilder i høy kvalitet her
https://www.flickr.com/photos/pelsjeger_photos/albums/72157642794564174
Om du har noe annet morsomt å bytte med kan jeg være åpen for dette. Integrert, høytt, eller effekt. Da fortrinnsvis stativhøyttalere av suveren kvalitet, og i nogen lunde samme prisklasse ny som denne.
Ta kontakt på tlf, mail eller PM for en hyggelig handel.
pelsjeger
Torget karakterer
Vurderinger (4)
