Erdal Stereo
Butikk Karan Master Collection POWERb MONO
Effektforsterker
Selges
Tilstand
Ny
Utløpsdato
Fylke/land
Hordaland
Pris
Kr 960.000
Annonse beskrivelse
Annonse nummer: 240245
Karan Master Collection POWERb MONO – mono power amplifier
Karan Master Collection er nå komplett:
LINEa, PHONOa, POWERa og POWERa mono.
LINEb, PHONOb, POWERb og POWERb mono.
Fra 1999 har Karan hatt 3 serier med effekttrinn / monoblokker og 4 serier med forforsterkere, alle komponentene er i bruk hos kunder i dag!
Technical specifications
The following data were consistently measured on random test objects and are typical of the product in question. Nominal operating mains (AC) voltage of all our products is 115V or 230V. If the mains supply voltage drops approximately 10% below its nominal value, the power output of our amplifiers will reduce itself by approximately 15%.
INPUTS: 1 balanced (XLR) and 1 unbalanced (RCA)
INPUT IMPEDANCE: 30 kOhm (balanced/unbalanced)
INPUT SENSITIVITY: 2.0 V/RMS (for max output)
GAIN: + 36dB
XLR PIN LAYOUT: PIN 1-ground, PIN 2-positive signal, PIN 3-negative signal
(when use RCA input you need to insert XLR shorting plug!)
POWER OUTPUT: 1.200/2.100/3.600W at 8/4/2ohm
(peak power output: 1.500W at 8ohm)
FREQUENCY RESPONSE: 20 Hz to 20 kHz, +/-0 dB; (DC to 300kHz,-3dB)
DISTORTION: THD 0.03%
IMD 0.03%
TRANSIENT RESPONSE: Rise and Settling time < 450 ns
Slew rate 1.500 V/us (Amplification stages)
SIGNAL TO NOISE RATIO: > 120 dB (unweighted)
POWER SUPPLY: 2pcs of 2.100VA low noise toroidal transformers,
180.000uF custom made capacitors bank
AC VOLTAGE: 115 V or 230 V (nominal line voltage)
AC VOLTAGE RANGE: +/- 10% (from nominal line voltage)
WARRANTY: 5 years, parts and labor
NET DIMENSIONS: 504 x 292 x 521mm (whd); 19.8 x 11.5 x 20.5 inch (whd)
NETWEIGHT: 81kg / 178lbs (each)
PACKAGE DIMENSIONS: 720 x 410 x 738mm (whd); 28.3×16.1×29 inch (whd)
PACKAGEWEIGHT: 103kg/226lbs (each)
De spiller åpent, klart, gjennomsiktig, utmerket romfølelse, kropp og kontroll, ren dyp bass eller kort og godt:
De spiller MUSIKK!
De blir ikke varme ved bruk, gir meget lang levetid!
Bestillingsvare, innbytte mulig!
Pris avhengig av valutakurs!
Koster i USA 85000 USD!
Pris avhengig av kronekurs!
Originalemballasje
Ja
Orig. kvittering
Ja
Forsendelse
Kan sendes
Erdal Stereo
Torget karakterer
Vurderinger (31)
Andre annonser av Erdal Stereo
