R
KRELL s300i
Denne annonsen er utgått.
Integrert forsterker
Selges
Tilstand
Brukt
Utløpsdato
Fylke/land
Akershus
Pris
Kr 9.000
Annonse beskrivelse
Annonse nummer: 244430
Krell s300i i god stand. selges
Her er noen anmeldelser:
https://www.theabsolutesound.com/articles/tested-krell-s-300i-integrated-amplifier/ https://6moons.com/audioreviews/krell3/krell.html https://www.soundandvision.com/content/krell-s-300i-integrated-stereo-amplifier
Og her er spec:
Inputs
1 pr. balanced via XLR connectors
3 pr. single-ended via RCA connectors
1 dedicated iPod input via 30-pin connector
Outputs
1 pr. preamp outputs via RCA connectors
1 pr. speaker outputs via gold-plated binding posts Control
inputs
1 RS-232 input via 9-pin D-subminiature connector
1 remote IR detector input via 3-conductor 3.5 mm connector
1 12 VDC trigger input via 2-conductor 3.5 mm connector
Control output
1 programmable 12 VDC trigger output (30 mA maximum current) via 2-conductor 3.5 mm connector
Input impedance
Balanced: 95 kΩ
Single-ended: 47.5 kΩ
Frequency response
20 Hz to 20 kHz +0, -0.14 dB
<2 Hz to 110 kHz +0, -3 dB
Signal-to-noise ratio
>84 dB, wideband, unweighted, at maximum gain, referred to full power output >93 dB, "A"-weighted
Gain
32.5 dB
Input sensitivity
Single-ended or balanced: 800 mV RMS
Total harmonic distortion
<0.035% at 1 kHz, at 150 W, 8 Ω load
<0.26% at 20 kHz, at 150 W, 8 Ω load
Output power
150 W RMS per channel at 8 Ω
300 W RMS per channel at 4 Ω
Output voltage
99 V peak to peak 35 V RMS
Output current
15 A peak
Slew rate
50 V/S
Output impedance
<0.080 Ω at 20 Hz
<0.11 Ω, 20 Hz to 20 kHz
Damping factor
>100 at 20 Hz, referred to 8 Ω
>75, 20 Hz to 20 kHz, referred to 8 Ω
Power consumption
Standby: 40 W
Idle: 60 W
Maximum: 1000 W
Heat output
Standby: 140 BTU/hr
Idle: 210 BTU/hr
Maximum: 1600 BTU/hr
Specifications for preamp only:
Gain
6.3 dB (single-ended)
Volume control
Current-mode, 12-bit, discrete R-2R ladder
Input overload
Balanced: 12 V RMS
Single-ended: 6 V RMS
Output overload
8 V RMS (single-ended)
Frequency response
20 Hz to 20 kHz +0, -0.05 dB
<2 Hz to 1.0 MHz +0, -3 dB
<0.009%, 20 Hz to 20 kHz, at 2 V RMS
>85 dB, wideband, unweighted, at maximum gain, referred to 2 V RMS
>94 dB, "A"-weighted
Dimensions
17.26 in W x 4.09 in H x 17.70 in D
438 mm W x 104 mm H x 450 mm D
Weight
Unit only: 42 lb [19.0 kg]
As shipped: 51 lb [23.1 kg]
Originalemballasje
Ja
Orig. kvittering
Nei
Forsendelse
Avtales nærmere
rusten
Torget karakterer
Vurderinger (2)
