"Kudos Titan 505 er en av verdens absolutt beste stativhøyttalere!"
Denne høyttaleren må bare oppleves !
Les testen: https://rognlien.wordpress.com/2019/10/30/titanenes-inntogsmars
Veil utsalgs pris: kr 89 000
Liten i størrelse - men altoppslukende. Hvis det er hverdagslig musikkglede du er på jakt etter, tilbyr Titan 505 dette med alle de viktigste elementene fra Titan serien i en kompakt stativhøyttaler.
TITAN 505
The newest addition to our flagship Titan series, the Kudos Titan 505 is a standmount loudspeaker designed to deliver stunning, top-of-range performance to a wider range music lovers. Small on size, big on immersion. If it’s everyday elation you’re after, the 505 offers all of the key Titan design features in a compact enclosure.
Type
TITAN 505
Type
- 2-way
- Isobaric bass reflex
- standmount
- 25W-250W
- @ 1W
- 1m
- 87dB
- 6 ohms
- 40Hz – 30kHz AIRR (average in-room response)
- SEAS – Kudos Crescendo K3 29mm fabric dome
- 2 x SEAS-Kudos 180mm unit with double coated paper cone, 39mm voice coil with copper shorting ring and aluminium phase plug
- 450mm (h) x 256mm (w) x 320mm (d)
- 18 kg
- Originalemballasje
- Ja
- Forsendelse
- Kan sendes
