PRE1 er en rørbasert forforsterker basert på E88cc trioden. PRE1 har fem analoge innganger og to variable utganger. Lydmessig har den en varm klangkarakter, som mange vil like.
Features: Toroidal power transformer Blue Velvet ALPS potentiometer Special Audio Grade parts in every stage No feedback design SRSG® implementation fine symmetry® implementation Gold plated Teflon rca connectors Gold plated tube sockets Remote control 5mm Aluminum face panel with luxury painting Five Years Guarantee Specifications: Power: 230/240 Vac 50Hz (1Α fused) Power consumption: 80 VA max Frequency responce: +0-3dB, 5Hz to 200kHz Distortion: 0.04% at 2V RMS output Gain: 21dB Signal to Noise ratio: 90dB Maximum output: 14V RMS Input impedance: 50K ohms Output impedance: 900 ohm Tube complement: 2x E88CC dual triode, (tube audio circuit, solid-state power supply) Warm up time: 1 minute Inputs: 5x line stereo (RCA connectors) Preamp outputs: 2xline stereo Available colors: Matt Black Dimensions (WxHxD): 43x11x29 cm Weight: 6 Kg
- Originalemballasje
- Ja
- Orig. kvittering
- Ja
- Forsendelse
- Kan sendes
